Hi, I was integrating the CPU pinning option to the OpenNebula LXD Driver, and it seems that the limits.cpu pinning option pins every process of the container starting from its init process, however, the monitor process of the container is not pinned. KVM/libvirt has an emulatorpin tag which allows to pin the emulator itself to specific cores (i think this is somewhat analogous to the monitor process).
Here is some process info. The first container is pinned to cpu 0 and the second one to cpu 1 and 2
17412 2 [lxc monitor] /var/lib/lxd/containers one-113
17430 0 /sbin/init
17501 0 /lib/systemd/systemd-udevd
17515 0 /usr/sbin/cron -f
17517 0 /usr/sbin/rsyslogd -n
17519 0 /lib/systemd/systemd-logind
17520 0 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
17858 0 /sbin/agetty --noclear --keep-baud console 115200 38400 9600 vt220
22533 3 [lxc monitor] /var/lib/lxd/containers one-116
22544 1 /sbin/init
22618 1 /lib/systemd/systemd-udevd
22637 1 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
22648 2 /usr/sbin/cron -f
22649 2 /lib/systemd/systemd-logind
22653 1 /usr/sbin/rsyslogd -n
22974 1 /sbin/agetty --noclear --keep-baud console 115200 38400 9600 vt220
root@dann1-server:~# lxc config show one-113 | grep limits.cpu
limits.cpu: 0-0
limits.cpu.allowance: 100%
root@dann1-server:~# lxc config show one-116 | grep limits.cpu
limits.cpu: 1,2
limits.cpu.allowance: 200%
I would like to pin the monitor process to the same set of cpu as the container. Does LXD provide the option ?
