Hi
I am trying to get a vm. My launch command is:
lxc launch ubuntu:22.04 ubuntu2204vm --vm --profile default --profile x11
and I get this error:
Error: Failed instance creation: Failed creating instance record: Failed initialising instance: Invalid devices: Device validation failed for “PASocket”: Only NAT mode is supported for proxies on VM instances
The problem seems to be in my x11 profile. This x11 profile works well with containers though (obtained from: [Running X11 software in LXD containers – Mi blog lah!]
environment.DISPLAY: :0
environment.PULSE_SERVER: tcp:127.0.0.1:4713
raw.idmap: both 1000 1000
user.user-data: |
#cloud-config
runcmd:
- 'sed -i "s/; enable-shm = yes/enable-shm = no/g" /etc/pulse/client.conf'
- 'echo export PULSE_SERVER=tcp:127.0.0.1:4713 | tee --append /home/ubuntu/.profile'
packages:
- x11-apps
- mesa-utils
- pulseaudio
- v4l-utils
description: GUI LXD profile
PASocket:
bind: container
connect: tcp:127.0.0.1:4713
listen: tcp:127.0.0.1:4713
type: proxy
X0:
bind: container
connect: unix:@/tmp/.X11-unix/X0
listen: unix:@/tmp/.X11-unix/X0
security.gid: "1000"
security.uid: "1000"
type: proxy
mygpu:
gid: "1000"
type: gpu
video0:
gid: "1000"
path: /dev/video1
type: unix-char
used_by: []
How can I solve this issue ?
Thanks a lot
Julia
