Can you please let me know how do I create an unprivileged container on Android?
Have you created and tested any LXC unprivileged containers on Android?
Regards
Venkata
Regards
Venkata
Hi!
See this discussion, Create an android container that works as an engine to run android apps
Assuming that you want to run LXC on Android:
You can find information about that, for example there are some youtube videos showing the use of LXC on Android: https://www.youtube.com/results?search_query=lxc+on+android&page=&utm_source=opensearch
Besides that I would believe that it works no different than normal use, but I never tried so that is only a guess and not confirmed.
