I would like to forward a mysql unix socket from the container to the host. It doesn’t work if the directory doesn’t already exist:
$ incus config device add librenms mysql proxy listen=unix:/run/mysqld/mysqld.sock connect=unix:/run/mysqld/mysqld.sock bind=instance
Error: Failed to start device "mysql": Error occurred when starting proxy device: Error: Failed to listen on /run/mysqld/mysqld.sock: listen unix /run/mysqld/mysqld.sock: bind: no such file or directory
If I manually create the directory before adding the proxy device, it’s fine. But I want this to work at container startup.
I put this in /etc/tmpfiles.d/mysql-sock.conf:
#Type Path Mode UID GID Age Argument
d /run/mysqld 0755 root root - -
Then added the device, restarted the container, and it seems to work.
My question is: is this safe, or is there a race condition here? i.e. is it guaranteed that the systemd-tmpfiles service will have completed before incus tries to create the /run/mysqld/mysqld.sock socket?
Thanks, Brian.
