I installed lxd using snap and facing issue while taking stateful snapshot Please help me how to resolve this.
root@colin-GL503VM:~# lxc list
| desired-chigger | RUNNING | 10.98.59.18 (eth0) | | PERSISTENT | 0 |
root@colin-GL503VM:~# lxc snapshot desired-chigger snap1 --stateful
Error: Unable to create a stateful snapshot. CRIU isn’t installed
root@colin-GL503VM:~# criu
Usage:
criu dump|pre-dump -t PID []
criu restore []
criu check [–feature FEAT]
criu exec -p PID
criu page-server
criu service []
criu dedup
Commands:
dump checkpoint a process/tree identified by pid
pre-dump pre-dump task(s) minimizing their frozen time
restore restore a process/tree
check checks whether the kernel support is up-to-date
exec execute a system call by other task
page-server launch page server
service launch service
dedup remove duplicates in memory dump
cpuinfo dump writes cpu information into image file
cpuinfo check validates cpu information read from image file
Try -h|–help for more info
root@colin-GL503VM:~# lxc config show
config: {}
root@colin-GL503VM:~# lxc network show lxdbr0
ipv4.address: 10.98.59.1/24
ipv4.nat: “true”
ipv6.address: none
description: “”
type: bridge
- /1.0/containers/desired-chigger
managed: true
status: Created
locations: - none
root@colin-GL503VM:~# lxc storage show default
source: /var/snap/lxd/common/lxd/storage-pools/default
description: “”
driver: dir
used_by: - /1.0/containers/desired-chigger
- /1.0/profiles/default
status: Created
locations: - none
root@colin-GL503VM:~# lxc profile show default
config: {}
nictype: bridged
parent: lxdbr0
pool: default
An Update
Found some information on CRIU on the compare page of LXD vs LXC and tried it also.
root@colin-GL503VM:~# snap set lxd criu.enable=true
root@colin-GL503VM:~# systemctl reload snap.lxd.daemon
Error: snapshot dump failed
(00.000021) Warn (criu/log.c:203): The early log isn’t empty
(00.061961) Warn (criu/net.c:2910): Unable to get tun network namespace
(00.358606) Warn (criu/image.c:134): Failed to open parent directory
(00.362753) Error (criu/sk-netlink.c:77): netlink: The socket has data to read
(00.362787) Error (criu/cr-dump.c:1344): Dump files (pid: 2709) failed with -1
(00.365225) Error (criu/cr-dump.c:1742): Dumping FAILED.
Please guide me to take stateful snapshot
