I’ve been trying to run travis-worker locally however I’m running into LXC storage volume issues.
root@travis-worker-anup:~# lxc storage volume list data
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| custom | travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker | | filesystem | 0 |
root@travis-worker-anup:~# lxc storage volume delete data travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker
Storage volume travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker deleted
As you can see, even though the delete command returns that the storage volume was deleted, it’s still showing up in the list. It’s very annoying since this error gets travis-worker to fail with
level=error msg="couldn't create the container Docker storage volume" err="Volume name \"travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker\" already exists."
root@travis-worker-anup:~# lxc storage show data
source: /mnt/travis-docker-data
driver: dir
- /1.0/storage-pools/data/volumes/custom/travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker
status: Created
locations:
- none
lxd init --auto
mkdir /mnt/data
lxc storage create data dir source=/mnt/data
Storage pool data created
lxc storage volume create data travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker
Storage volume travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker created
lxc storage volume ls data
ls /mnt/data/custom
default_travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker
ls /mnt/data/custom
Can you manually remove /mnt/travis-docker-data/custom/default_travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker?
I’ve tried rebooting but unfortunately doesn’t do anything.
What error do you get though?
Nothing. I removed the /mnt/travis-docker-data/custom/default_travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker directory myself and ran lxc storage volume delete data travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker just to be sure. It still doesn’t get rid of that storage volume.
So instead of deleting /mnt/travis-docker-data/custom/default_travis-job-xxxxxxxx-xxxxx-travis-job-721271-docker I deleted the whole custom directory as it only had “default_travis-job…”
and then made an empty custom directory, which seems to have resolved the issue.
Anyway, here’s the thing you asked for:
ubuntu@travis-worker-anup:~/worker$ sudo lxd sql global 'select * from storage_pools'
| id | name | driver | description | state |
| 3 | instances | zfs | | 1 |
| 4 | data | dir | | 1 |
OK good. Although I don’t think we can identify and resolve the bug in LXD now that you’ve made manual changes. I was really after the debug log I requested to see why LXD thought it had removed it when it had left both the dir and the DB record behind.
I’ll try to reproduce the situation again. I ran into it after repeatedly cancelling travis jobs while they were executing, and I’ll keep the debug monitor running
