I just realized - I have two custom volumes that are mounted on several instances via their inclusion on a profile. However the “used by” column is not the number of instances or even the number of profiles it is included on but ‘0’
That sounds like a bug. I’ve definitely seen us correctly report resources like networks as being used by a profile.
Can you file an issue at Sign in to GitHub · GitHub?
Done, discovered its with --all-projects
