I am using gentoo and trying to use jessie. Unfortunately, DBUS hangs in jessie
# lxc exec jessie bash
root@jessie:~# systemctl status
Failed to get D-Bus connection: No such file or directory
root@jessie:~# apt-get install systemd
Reading package lists... Done
Building dependency tree
Reading state information... Done
systemd is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
● jessie
State: degraded
Jobs: 0 queued
Failed: 1 units
Since: Mon 2018-01-01 17:08:56 UTC; 36s ago
CGroup: /
├─ 1 /sbin/init
├─ 4 bash
├─97 systemctl status
├─98 pager
└─system.slice
├─console-getty.service
│ └─90 /sbin/agetty --noclear --keep-baud console 115200 38400 9600 linux
├─networking.service
│ └─68 dhclient -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases eth0
└─systemd-journald.service
└─21 /lib/systemd/systemd-journald
root@jessie:~# apt-get install dbus
The following extra packages will be installed:
libcap-ng0 libdbus-1-3 libexpat1
Suggested packages:
dbus-x11
The following NEW packages will be installed:
dbus libcap-ng0 libdbus-1-3 libexpat1
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 555 kB of archives.
After this operation, 1737 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
0% [Connecting to deb.debian.org (2001:41c8:1000:21::21:4)]^C
root@jessie:~# apt-get install dbus -y
Suggested packages:
dbus-x11
Get:1 http://deb.debian.org/debian/ jessie/main libcap-ng0 amd64 0.7.4-2 [13.2 kB]
Get:2 http://deb.debian.org/debian/ jessie/main libdbus-1-3 amd64 1.8.22-0+deb8u1 [170 kB]
Get:3 http://deb.debian.org/debian/ jessie/main libexpat1 amd64 2.1.0-6+deb8u4 [80.2 kB]
Get:4 http://deb.debian.org/debian/ jessie/main dbus amd64 1.8.22-0+deb8u1 [292 kB]
Fetched 555 kB in 1s (318 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libcap-ng0:amd64.
(Reading database ... 8627 files and directories currently installed.)
Preparing to unpack .../libcap-ng0_0.7.4-2_amd64.deb ...
Unpacking libcap-ng0:amd64 (0.7.4-2) ...
Selecting previously unselected package libdbus-1-3:amd64.
Preparing to unpack .../libdbus-1-3_1.8.22-0+deb8u1_amd64.deb ...
Unpacking libdbus-1-3:amd64 (1.8.22-0+deb8u1) ...
Selecting previously unselected package libexpat1:amd64.
Preparing to unpack .../libexpat1_2.1.0-6+deb8u4_amd64.deb ...
Unpacking libexpat1:amd64 (2.1.0-6+deb8u4) ...
Selecting previously unselected package dbus.
Preparing to unpack .../dbus_1.8.22-0+deb8u1_amd64.deb ...
Unpacking dbus (1.8.22-0+deb8u1) ...
Processing triggers for systemd (215-17+deb8u7) ...
Setting up libcap-ng0:amd64 (0.7.4-2) ...
Setting up libdbus-1-3:amd64 (1.8.22-0+deb8u1) ...
Setting up libexpat1:amd64 (2.1.0-6+deb8u4) ...
Setting up dbus (1.8.22-0+deb8u1) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
● jessie
State: degraded
Jobs: 1 queued
Failed: 2 units
Since: Mon 2018-01-01 17:08:56 UTC; 4min 49s ago
CGroup: /
├─ 1 /sbin/init
├─ 4 bash
├─274 systemctl status
├─275 pager
└─system.slice
root@jessie:~# systemctl --failed
UNIT LOAD ACTIVE SUB JOB DESCRIPTION
● dev-hugepages.mount loaded failed failed Huge Pages File System
● dbus.service loaded failed failed start D-Bus System Message Bus
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
JOB = Pending job for the unit.
2 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
Cgroups on host
$ mount|grep cgroup
cgroup_root on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,relatime,size=10240k,mode=755)
openrc on /sys/fs/cgroup/openrc type cgroup (rw,nosuid,nodev,noexec,relatime,release_agent=/lib64/rc/sh/cgroup-release-agent.sh,name=openrc)
none on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
cpuset on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cpu on /sys/fs/cgroup/cpu type cgroup (rw,nosuid,nodev,noexec,relatime,cpu)
cpuacct on /sys/fs/cgroup/cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpuacct)
blkio on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
memory on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
devices on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
freezer on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
perf_event on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
pids on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,relatime,name=systemd)
mount inside container
# mount
/var/lib/lxd.img on / type btrfs (rw,relatime,space_cache,subvolid=5,subvol=/storage-pools/default/containers/jessie/rootfs)
none on /dev type tmpfs (rw,relatime,size=492k,mode=755,uid=1000000,gid=1000000)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,relatime)
devtmpfs on /dev/net/tun type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/lxd type tmpfs (rw,relatime,size=100k,mode=755)
tmpfs on /dev/.lxd-mounts type tmpfs (rw,relatime,size=100k,mode=711)
devtmpfs on /dev/null type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devtmpfs on /dev/zero type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devtmpfs on /dev/full type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devtmpfs on /dev/urandom type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devtmpfs on /dev/random type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devtmpfs on /dev/tty type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=1012556,mode=755)
devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
devpts on /dev/pts type devpts (rw,relatime,gid=1000005,mode=620,ptmxmode=666)
devpts on /dev/ptmx type devpts (rw,relatime,gid=1000005,mode=620,ptmxmode=666)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,uid=1000000,gid=1000000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755,uid=1000000,gid=1000000)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,uid=1000000,gid=1000000)
tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,mode=755,uid=1000000,gid=1000000)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,name=systemd)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
If i try to use dbus in Debian Stretch container it works,
root@stretch:~# systemctl status dbus
● dbus.service - D-Bus System Message Bus
Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled)
Active: active (running) since Mon 2018-01-01 17:20:04 UTC; 25s ago
Docs: man:dbus-daemon(1)
Main PID: 242 (dbus-daemon)
CGroup: /system.slice/dbus.service
└─242 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
Jan 01 17:20:04 stretch systemd[1]: dbus.service: Failed to reset devices.list: Operation not permitted
Jan 01 17:20:04 stretch systemd[1]: dbus.service: Failed to set invocation ID on control group /system.slice/dbus.service, ignoring: Operation not permitted
Jan 01 17:20:04 stretch systemd[1]: Started D-Bus System Message Bus.
Finally,
$ lxc info
config: {}
api_extensions:
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
api_status: stable
api_version: "1.0"
auth: trusted
public: false
environment:
addresses: []
architectures:
- x86_64
- i686
driver: lxc
driver_version: 2.0.9
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.9.72-gentoo
server: lxd
server_pid: 5189
server_version: "2.19"
storage: dir
storage_version: "1"
