I have question who seems to be dumb.
Host: Ubuntu 20.04
LXD: 4.4
| bastion01 | RUNNING | 192.168.10.201 (eth1) | | CONTAINER | 0 |
| | | 10.69.10.12 (eth0) | | | |
| apps | RUNNING | 192.168.10.162 (eth1) | | CONTAINER | 0 |
| | | 10.69.10.11 (eth0) | | | |
| lxdmosaic01 | RUNNING | 192.168.10.117 (eth1) | | CONTAINER | 0 |
| | | 10.69.10.55 (eth0) | | | |
| mariadb-master | RUNNING | 10.69.10.10 (eth0) | | CONTAINER | 0 |
| prometheus01 | RUNNING | 192.168.10.45 (eth1) | | CONTAINER | 0 |
| | | 10.69.10.166 (eth0) | | | |
| reverseproxy01 | RUNNING | 192.168.10.202 (eth1) | | CONTAINER | 0 |
| | | 10.69.10.174 (eth0) | | | |
All containers run under Ubuntu 20.04 except apps who is under Debian10.
All Ubuntu’s container can ping without problem all DNS.
for example, from bastion01
ping prometheus01.lxd works
ping prometheus01.lan works
lxc exec bastion01 -- cat /etc/resolv.conf
nameserver 127.0.0.53
options edns0
search lan lxd
But espacially for apps container (Debian10) I have problem.
lxc exec apps -- cat /etc/resolv.conf
domain lan
search lan
nameserver 192.168.10.16
I needed to do:
lxc exec apps -- dhclient
to obtain:
domain lxd
search lxd
nameserver 10.69.10.1
And after that, my debian10 container works fine! I can ping all dns. And my apps installed on work after.
My debian 10 interfaces:
cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
source /etc/network/interfaces.d/*
and
cat /etc/network/interfaces.d/eth1
auto eth1
iface eth1 inet dhcp
Others infos:
lxc network show lxdbr0
ipv4.address: 10.69.10.1/24
ipv4.nat: "true"
ipv6.address: none
ipv6.nat: "true"
volatile.bridge.hwaddr: 00:16:3e:5d:4d:57
type: bridge
- /1.0/instances/bastion01
- /1.0/instances/apps
- /1.0/instances/lxdmosaic01
- /1.0/instances/mariadb-master
- /1.0/instances/prometheus01
- /1.0/instances/reverseproxy01
- /1.0/profiles/default
- /1.0/profiles/lanprofile
managed: true
status: Created
locations:
- none
Profiles:
lxc profile show lanprofile
config: {}
description: conf for eth on lan dhcp
nictype: bridged
parent: lxdbr0
eth1:
nictype: bridged
parent: brvlan
pool: data
What is the best practices to have the right revolv.conf on debian 10 container?
I prefer to no have to create dirty sh script to run by cron of maybe change something on dhclient.conf. Does LXD have a magic solution?
Thanks
