Hi when I use gnome-system-monitor in my container. It lists only 3 CPUs. I did not set a limit to the number of CPUs. Is gnome-system-monitor wrong or the cpu limit is setup by default.
lxc config show --expanded does not list and cpu parameters.
Probably just wrong, what does cat /proc/cpuinfo show you?
/proc/cpuinfo lists all the cpus in the system. May it is just an issue with gnome-system-monitor. I am just curious why it is listing 3 cpus. In the host gnome-system-monitor lists all the cpus.
yeah, not sure, it must be getting confused by something…
3 is a rather weird number too
