Default instance type for a project
Is there a way to specify default instance type for a project or a specific remote?
The use case for this is with juju. I will like to specify that a particular juju model use a particular instance type for machines added from the model.
This also arose from the issue I was having here so I need to launch a virtual machine type as I think it solves my issue ubuntu-session-restarts-on-lxd-start
I don’t think so, as remotes, projects and profiles are instance type agnostic.
What you really need is LXD VM support in juju, but I don’t think that exists.
@sdeziel @stgraber am I correct in thinking there’s no way to create a LXD VM via juju currently?
That is correct. Bug #1936188 “Remove KVM provider and use LXD --vm” : Bugs : juju is where the VM support was requested.
