$ lxc delete c1
Error: remove /var/lib/lxd/storage-pools/data/containers/c1: directory not empty
When I head over to that path it has a backup.yaml file. once I delete it I am able to delete the container.
root@lxdhost:/var/lib/lxd/storage-pools/data/containers/c1# ls -la
total 12
drwx--x--x 2 root root 4096 Mar 5 14:02 .
drwx--x--x 3 root root 4096 Mar 5 14:05 ..
-r-------- 1 root root 2480 Mar 5 14:02 backup.yaml
Why does this happen?
$ lxc info --show-log c1
Remote: unix://
Created: 2019/03/05 18:53 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc c1 20190305185404.738 WARN conf - conf.c:lxc_setup_devpts:1616 - Invalid argument - Failed to unmount old devpts instance
lxc c1 20190305185954.319 WARN network - network.c:lxc_delete_network_priv:2589 - Operation not permitted - Failed to remove interface "eth0" with index 43
This is the host setup:
$ lxd --version
3.0.3
$ uname -r
4.15.0-46-generic
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.2 LTS"
LXC monitor log:
lxc monitor
metadata:
context: {}
level: dbug
message: 'New event listener: 1ba6972a-0982-45c8-93bd-aa42a5d5f063'
timestamp: "2019-03-05T11:35:55.69848348-08:00"
type: logging
metadata:
context:
ip: '@'
method: GET
url: /1.0
level: dbug
message: handling
timestamp: "2019-03-05T11:35:59.835248242-08:00"
type: logging
metadata:
context:
ip: '@'
method: GET
url: /1.0/containers/c1
level: dbug
message: handling
timestamp: "2019-03-05T11:35:59.839415334-08:00"
type: logging
metadata:
context: {}
level: dbug
message: 'New event listener: b18bcb92-e704-4e60-8c56-f9acf34bb711'
timestamp: "2019-03-05T11:35:59.84578629-08:00"
type: logging
metadata:
context:
ip: '@'
method: GET
url: /1.0/events?project=
level: dbug
message: handling
timestamp: "2019-03-05T11:35:59.845636004-08:00"
type: logging
metadata:
context:
ip: '@'
method: DELETE
level: dbug
message: handling
timestamp: "2019-03-05T11:35:59.847069719-08:00"
type: logging
metadata:
context: {}
level: dbug
message: 'New task operation: bfbd9793-54f7-49f6-b0dd-eaee65c6cf12'
timestamp: "2019-03-05T11:35:59.852620721-08:00"
type: logging
metadata:
context: {}
level: dbug
message: 'Started task operation: bfbd9793-54f7-49f6-b0dd-eaee65c6cf12'
timestamp: "2019-03-05T11:35:59.852732104-08:00"
type: logging
metadata:
class: task
created_at: "2019-03-05T11:35:59.850553435-08:00"
description: Deleting container
err: ""
may_cancel: false
metadata: null
resources:
containers:
- /1.0/containers/c1
status: Pending
status_code: 105
updated_at: "2019-03-05T11:35:59.850553435-08:00"
timestamp: "2019-03-05T11:35:59.852672432-08:00"
type: operation
metadata:
context:
created: 2019-03-05 10:53:54 -0800 PST
ephemeral: "false"
used: 2019-03-05 10:54:04.42581804 -0800 PST
level: info
message: Deleting container
timestamp: "2019-03-05T11:35:59.852911648-08:00"
type: logging
metadata:
class: task
err: ""
may_cancel: false
metadata: null
resources:
containers:
status: Running
status_code: 103
timestamp: "2019-03-05T11:35:59.852755874-08:00"
type: operation
metadata:
context:
ip: '@'
method: GET
url: /1.0/operations/bfbd9793-54f7-49f6-b0dd-eaee65c6cf12
level: dbug
message: handling
timestamp: "2019-03-05T11:35:59.854309488-08:00"
type: logging
metadata:
context: {}
level: dbug
message: Deleting ZFS storage volume for container "c1" on storage
pool "data"
timestamp: "2019-03-05T11:35:59.862185234-08:00"
type: logging
metadata:
context:
err: 'remove /var/lib/lxd/storage-pools/data/containers/c1:
directory not empty'
level: eror
message: Failed deleting container storage
timestamp: "2019-03-05T11:35:59.867088703-08:00"
type: logging
metadata:
class: task
err: 'remove /var/lib/lxd/storage-pools/data/containers/c1: directory
not empty'
may_cancel: false
metadata: null
resources:
containers:
status: Failure
status_code: 400
timestamp: "2019-03-05T11:35:59.867219824-08:00"
type: operation
metadata:
context: {}
level: dbug
message: 'Failure for task operation: bfbd9793-54f7-49f6-b0dd-eaee65c6cf12: remove
empty'
timestamp: "2019-03-05T11:35:59.867167805-08:00"
type: logging
^C
@stgraber I am unable to reproduce this at will, but often when we run our automated tests this comes up. Any inputs to help debug this?
