Hi there,
I’m trying to setup pppoe server in LXC.
But, when client trying connect, server getting error:
Jul 03 13:29:10 pppoe pppd[100]: Couldn’t open the /dev/ppp device: Operation not permitted
Jul 03 13:29:15 pppoe pppd[100]: Sorry - this system lacks PPP kernel support
ofcourse I have added this lines to container’s config:
lxc.mount.entry = /dev/ppp dev/ppp none bind,optional,create=file,rw
lxc.cgroup.devices.allow = c 108:0 rwm
Also, i tried another way:
to config file and run
mknod /dev/ppp c 108 0
inside container, but it is not changing anything.
also not helping this on host:
chown 100000:100000 /dev/ppp
and if run container and add device like this:
lxc-device add -n pppoe /dev/ppp /dev/ppp
then it works!
But how to add device /dev/ppp permanently? Because need run this command after every container start.
Rights differences: first in config, second with lxc-device add
0 crw------- 1 root root 108, 0 Jul 3 13:23 /dev/ppp
0 crw------- 1 root root 108, 0 Jul 1 23:52 /dev/ppp
