In common I provide access to mailservers on a lxd host via container specific proxy configurations that listen on 127.0.0.1:25 inside the container and connect to 127.0.0.1:25 on the host.
With running docker inside a lxc container the docker containers know their docker0 at 172.17.0.1 bridge for networking, so I added the following device config to enable sending emails from inside docker containers:
lxc config device add mycontainer mailserver-docker proxy listen=tcp:172.17.0.1:25 connect=tcp:127.0.0.1:25 bind=container
This is a working setup. But things break when the lxc container needs to be (re)started: lxd tries to setup the device âmailserver-dockerâ and cannot listen to 172.17.0.1:25 because the docker bridge is started later on in the staring process (Error: Error occurred when starting proxy device: Error: Failed to listen on 172.17.0.1:25: listen tcp 172.17.0.1:25: bind: cannot assign requested address
Now I think about different approaches:
- use some docker-specific mechanism to bind port 25 to the lxc-specific port 25 that connects to port 25 on the host? Hint: I didnât find anything appropriate.
- checkout if lxd accepts scripts to be executed on shutdown (âdevice removeâ) and startup (repeatedly try to âdevice addâ ⊠not very nice)
- ask for an extension of
device add proxy
by the LXD team: if listening fails the container could be started with a warning only and the device could be attached later on with some retries.
Any (further) suggestions?
For background information:
# lxc ls -c ns4 mycontainer
| NAME | STATE | IPV4 |
| mycontainer | RUNNING | 192.168.96.1 (br-67879c888ac8) |
| | | 192.168.64.1 (br-467e39ed58ee) |
| | | 192.168.48.1 (br-0e0d44af9da9) |
| | | 192.168.32.1 (br-6b66559b7ca7) |
| | | 192.168.208.1 (br-78146addde19) |
| | | 192.168.144.1 (br-574905d87763) |
| | | 192.168.112.1 (br-7017a17107e3) |
| | | 192.168.0.1 (br-187bf916c8d8) |
| | | 172.31.0.1 (br-48e056798521) |
| | | 172.30.0.1 (br-ec9b4eb276b1) |
| | | 172.29.0.1 (br-d7d7e96fcbc3) |
| | | 172.28.0.1 (br-ff3430e2408f) |
| | | 172.25.0.1 (br-b754a3b64228) |
| | | 172.24.0.1 (br-d4fbc8315c5d) |
| | | 172.23.0.1 (br-ec45feafd8ec) |
| | | 172.20.0.1 (br-a63dcaf4beac) |
| | | 172.19.0.1 (br-668398d3183b) |
| | | 172.18.0.1 (br-b0f213c37afb) |
| | | 172.17.0.1 (docker0) |
| | | 10.187.210.165 (eth0) |
# lxc config device list mycontainer
mailserver
mailserver-docker
# lxc stop mycontainer
# lxc start mycontainer
Try `lxc info --show-log mycontainer` for more info
My Workaround:
# lxc config device remove mycontainer mailserver-docker
Device mailserver-docker removed from mycontainer
# lxc config device add mycontainer mailserver-docker proxy listen=tcp:172.17.0.1:25 connect=tcp:127.0.0.1:25 bind=container
Device mailserver-docker added to mycontainer
