Differences in Network Setup between incus and LXD?
We’re right now evaluating incus on Fedora 40 (KDE Beta). I’ve followed the instructions for and from the COPR. Afterwards I’ve proceeded like I can remember it from LXC:
The incusbr0 exists and the listed IP address is pingable:
But when I look into the container (which was a simple incus launch images:ubuntu/22.04) I see no IPv4 address:
This also didn’t change after a full host system restart.
Am I forgetting something or is there any difference in the Networking? The system environment is vastly different, before we used the LXD snap in Ubuntu 22.04 and now this is Fedora 40 incus via COPR.
PS:
  • When I run dhclient inside of the container it never gets a DHCP reply.
  • The incus version is 0.7
  • dnsmasq is in fact running as a process dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=incusbr0 --dhcp-rapid-commit --no-negcache --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=10.186.9.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/lib/incus/networks/incusbr0/dnsmasq.leases --dhcp-hostsfile=/var/lib/incus/networks/incusbr0/dnsmasq.hosts --dhcp-range 10.186.9.2,10.186.9.254,1h -s incus --interface-name _gateway.incus,incusbr0 -S /incus/ --conf-file=/var/lib/incus/networks/incusbr0/dnsmasq.raw -u nobody -g incus
This is the default profile:
And this is the container config:
Most likely firewalld blocking the traffic.
I had the same with Ubuntu and ufw: the DHCP traffic was being blocked. Solution:
ufw allow in on incusbr0
ufw route allow in on incusbr0
Thank you two, it was in fact the default installation/config of firewalld on Fedora 40.
And these lines just like in the manual fixed the issue for me:
sudo firewall-cmd --zone=trusted --change-interface=incusbr0 --permanent
sudo firewall-cmd --reload
