Dir type storage pool is taking double space
I am trying to create a new storage pool in a new HDD to try to save main disk space:
1 create new storage pool
incus storage create test dir source=/new_disk_mount_point
2 create new virtual machine in the new storage pool
incus launch ubuntu24 test-1 --vm --storage=test
but when I inspect the /var/lib/incus/storage-pools directory, I found that the new VM is still taking up space there. Plus the new space at the new storage pool source directory.
so basically one VM is taking double disk space: one in the /var/lib/storage-pools/test and one in the /new_disk_mount_point/
I just tested exactly what you did:
mkdir /new_disk_mount_point
incus launch images:ubuntu/24.04/cloud test-1 --vm --storage=test
I do see the same storage at two different places in the file tree, but it’s a bind mount. Note that the inode numbers are all the same:
root@nuc3:~# ls -i /new_disk_mount_point/
524410 buckets     524421 containers-snapshots  524418 custom-snapshots  524422 virtual-machines
524420 containers  524417 custom                524419 images            524423 virtual-machines-snapshots
root@nuc3:~# ls -i /var/lib/incus/storage-pools/test/
root@nuc3:~# mount | grep storage-pools/test
/dev/mapper/vg0-root on /var/lib/incus/storage-pools/test type ext4 (rw,relatime)
So I’m pretty confident it’s not using any space under /var/lib/incus/storage-pools; it just looks like it because the storage directory is also mounted there.
that solve my puzzle, thanks.
Thanks for the explanation @candlerb. I was confused too and I didn’t want to believe incus could just duplicate a pool as it would be too stupid, but checking bind mount simply didn’t came into my mind :smiley: Thanks!
