Hiya,
Does anyone know how to disable Netplan in an 18.04 container?
Normally I would disable it in /etc/default/grub using the “do_not_use_netplan=true” command (update-grub) and then apt install ifupdown.
I want to use openvswitch and as far as I’m aware netplan can’t control openvswitch and I’d rather not call scripts on startup, I like the ifupdown way!
Cheers,
Jon.
