I’ve been familiarising with Distrobuilder. I’m trying to use the --import-into-lxd to import the images into a remote lxd. I can’t work out how to do that, if it’s possible.
Doing it as a two-step works fine, i.e. bulding with distrobuilder and then doing lxc image import lxd.tar.xz rootfs.squashfs myserver: --alias myimage.
Is it possible for Distrobuilder to import directly into a remote ?
