I’m investigating distrobuilder. In the documentation there are a few build options:
build-dir Build plain rootfs
build-incus Build Incus image from scratch
build-lxc Build LXC image from scratch
What is the differences in the final images built with these three options?
I assumed https://images.linuxcontainers.org/ uses the build-lxc option and that those images can also be used with incus so I’m a bit confused why there is a incus-specific build option.
LXC images are just a plain tar.xz tarball, Incus supports squashfs as well as binary deltas on top of squashfs. It also comes with template files (pongo2) and additional metadata compared to the plain tarball that LXC consumes.
