I have a script that creates a container and installs AdGuard Home in the container. Once done, I change my router’s DNS IP to that of my host and reboot the host system.
Generally I have internet after reboot is done, but I have noticed that this is not happening all the time. Some times I reboot and it seems like the DNS is not working, and in fact I have no connection to the internet.
If I reboot again, I might or might not have a connection to the internet. What I noticed is that when I don’t have internet, and restart the DNS container, internet comes back up. So all it takes is a container restart to get it back to working. I would like to avoid this and have DNS and internet immediately once the machine has rebooted.
Anyone had a similar scenario? Any help how I can debug this? I’m at a loss, I’ve spent a whole week trying to different scenarios and restarting the system and sometimes I still have no connection to the internet.
Some other details:
System running rasbian lite and container running debian/11/armhf
When I don’t have connection, the container is running, has an IP and also adguard status shows that it is running.
Ports forwarded for the DNS container:
proxy53T:
connect: tcp:127.0.0.1:53
listen: tcp:10.0.0.4:53
type: proxy
proxy53U:
connect: udp:127.0.0.1:53
listen: udp:10.0.0.4:53
type: proxy
proxy80:
connect: tcp:127.0.0.1:80
listen: tcp:10.0.0.4:80
type: proxy
proxy443:
connect: tcp:127.0.0.1:443
listen: tcp:10.0.0.4:443
type: proxy
proxy3000:
connect: tcp:127.0.0.1:3000
listen: tcp:10.0.0.4:3000
type: proxy
proxy8080:
connect: tcp:127.0.0.1:8080
listen: tcp:10.0.0.4:10301
type: proxy
proxy51820:
connect: udp:127.0.0.1:51820
listen: udp:10.0.0.4:51820
type: proxy
