In a nutshell my problem seems to be related to networking and container nesting. Here’s the hierarchy of components and where the problem is:
- (1) Ubuntu 20.04.3 LTS (has internet
- (2) LXD
- (3) Debian bullseye container (has internet
- (4) Docker CE
- (5)
ubuntu:latestcontainer (has no internet
- (5)
- (4) Docker CE
- (2) LXD
From (1): the host
> sudo iptables -vL
Chain INPUT (policy ACCEPT 20719 packets, 43M bytes)
pkts bytes target prot opt in out source destination
0 0 ACCEPT icmp -- lxdbr0 any anywhere anywhere icmp parameter-problem /* generated for LXD network lxdbr0 */
0 0 ACCEPT icmp -- lxdbr0 any anywhere anywhere icmp time-exceeded /* generated for LXD network lxdbr0 */
0 0 ACCEPT icmp -- lxdbr0 any anywhere anywhere icmp destination-unreachable /* generated for LXD network lxdbr0 */
0 0 ACCEPT tcp -- lxdbr0 any anywhere anywhere tcp dpt:domain /* generated for LXD network lxdbr0 */
110 6640 ACCEPT udp -- lxdbr0 any anywhere anywhere udp dpt:domain /* generated for LXD network lxdbr0 */
18 5864 ACCEPT udp -- lxdbr0 any anywhere anywhere udp dpt:bootps /* generated for LXD network lxdbr0 */
21743 43M LIBVIRT_INP all -- any any anywhere anywhere
692 87721 NFQUEUE udp -- any any anywhere anywhere udp spt:domain NFQUEUE num 0 bypass
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
11326 227M ACCEPT all -- any lxdbr0 anywhere anywhere /* generated for LXD network lxdbr0 */
10471 577K ACCEPT all -- lxdbr0 any anywhere anywhere /* generated for LXD network lxdbr0 */
0 0 LIBVIRT_FWX all -- any any anywhere anywhere
0 0 LIBVIRT_FWI all -- any any anywhere anywhere
0 0 LIBVIRT_FWO all -- any any anywhere anywhere
Chain OUTPUT (policy ACCEPT 24515 packets, 4360K bytes)
0 0 ACCEPT icmp -- any lxdbr0 anywhere anywhere icmp parameter-problem /* generated for LXD network lxdbr0 */
0 0 ACCEPT icmp -- any lxdbr0 anywhere anywhere icmp time-exceeded /* generated for LXD network lxdbr0 */
0 0 ACCEPT icmp -- any lxdbr0 anywhere anywhere icmp destination-unreachable /* generated for LXD network lxdbr0 */
0 0 ACCEPT tcp -- any lxdbr0 anywhere anywhere tcp spt:domain /* generated for LXD network lxdbr0 */
110 11392 ACCEPT udp -- any lxdbr0 anywhere anywhere udp spt:domain /* generated for LXD network lxdbr0 */
15 4986 ACCEPT udp -- any lxdbr0 anywhere anywhere udp spt:bootps /* generated for LXD network lxdbr0 */
24980 4417K LIBVIRT_OUT all -- any any anywhere anywhere
Chain LIBVIRT_FWI (1 references)
0 0 ACCEPT all -- any virbr0 anywhere 192.168.122.0/24 ctstate RELATED,ESTABLISHED
0 0 REJECT all -- any virbr0 anywhere anywhere reject-with icmp-port-unreachable
Chain LIBVIRT_FWO (1 references)
0 0 ACCEPT all -- virbr0 any 192.168.122.0/24 anywhere
0 0 REJECT all -- virbr0 any anywhere anywhere reject-with icmp-port-unreachable
Chain LIBVIRT_FWX (1 references)
0 0 ACCEPT all -- virbr0 virbr0 anywhere anywhere
Chain LIBVIRT_INP (1 references)
0 0 ACCEPT udp -- virbr0 any anywhere anywhere udp dpt:domain
0 0 ACCEPT tcp -- virbr0 any anywhere anywhere tcp dpt:domain
0 0 ACCEPT udp -- virbr0 any anywhere anywhere udp dpt:bootps
0 0 ACCEPT tcp -- virbr0 any anywhere anywhere tcp dpt:67
Chain LIBVIRT_OUT (1 references)
0 0 ACCEPT udp -- any virbr0 anywhere anywhere udp dpt:domain
0 0 ACCEPT tcp -- any virbr0 anywhere anywhere tcp dpt:domain
0 0 ACCEPT udp -- any virbr0 anywhere anywhere udp dpt:bootpc
0 0 ACCEPT tcp -- any virbr0 anywhere anywhere tcp dpt:68
To launch (3) - Debian LXD container:
lxc launch -c security.nesting=true images:debian/bullseye dockertest
lxc exec dockertest -- /bin/bash
Inside (3) - Debian LXD container, as root
# ping test
> ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=54 time=3.74 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=54 time=4.44 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=54 time=4.18 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=54 time=2.33 ms
^C
--- 1.1.1.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3006ms
rtt min/avg/max/mdev = 2.327/3.672/4.443/0.815 ms
# Install iptables, Docker-CE dependencies
> apt update && apt install -y ca-certificates curl gnupg lsb-release iptables
> curl -fsSL https://download.docker.com/linux/debian/gpg | gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
> echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian \
$(lsb_release -cs) stable" | tee /etc/apt/sources.list.d/docker.list > /dev/null
# Install Docker-CE
> apt update && apt install -y docker-ce docker-ce-cli containerd.io
# Double-check that internet still works (since I've seen in other places that
# Docker can mess up iptables forwarding rules, but it's fine for me here)
> ping 1.1.1.1
64 bytes from 1.1.1.1: icmp_seq=1 ttl=54 time=3.75 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=54 time=4.33 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 3.748/4.039/4.331/0.291 ms
Some networking config from within the Debian LXD container:
> iptables -vL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
0 0 DOCKER-USER all -- any any anywhere anywhere
0 0 DOCKER-ISOLATION-STAGE-1 all -- any any anywhere anywhere
0 0 ACCEPT all -- any docker0 anywhere anywhere ctstate RELATED,ESTABLISHED
0 0 DOCKER all -- any docker0 anywhere anywhere
0 0 ACCEPT all -- docker0 !docker0 anywhere anywhere
0 0 ACCEPT all -- docker0 docker0 anywhere anywhere
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
0 0 DOCKER-ISOLATION-STAGE-2 all -- docker0 !docker0 anywhere anywhere
0 0 RETURN all -- any any anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
0 0 DROP all -- any docker0 anywhere anywhere
Chain DOCKER-USER (1 references)
> ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:1c:0d:bb:9b txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.114.76.158 netmask 255.255.255.0 broadcast 10.114.76.255
inet6 fd42:1544:5012:6eba:216:3eff:fe25:dd5f prefixlen 64 scopeid 0x0<global>
inet6 fe80::216:3eff:fe25:dd5f prefixlen 64 scopeid 0x20<link>
ether 00:16:3e:25:dd:5f txqueuelen 1000 (Ethernet)
RX packets 7764 bytes 143383313 (136.7 MiB)
TX packets 7096 bytes 496110 (484.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
> cat /etc/resolv.conf
domain lxd
search lxd
nameserver 10.114.76.1
Back on (1) - the host system
lxc list dockertest
| dockertest | RUNNING | 172.17.0.1 (docker0) | fd42:1544:5012:6eba:216:3eff:fe25:dd5f (eth0) | CONTAINER | 0 |
| | | 10.114.76.158 (eth0) | | | |
lxc network show lxdbr0
ipv4.address: 10.114.76.1/24
ipv4.nat: "true"
ipv6.address: fd42:1544:5012:6eba::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/dockertest
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
Now back to (3) - Debian LXD container as root
# This works as expected, giving me an interactive prompt as root in an
# Ubuntu container.
docker run -it --rm ubuntu /bin/bash
Inside (5) - Docker ubuntu:latest container as root
> apt update
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
Temporary failure resolving 'archive.ubuntu.com'
Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:3 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Err:4 http://security.ubuntu.com/ubuntu focal-security InRelease
Temporary failure resolving 'security.ubuntu.com'
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Temporary failure resolving 'security.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
domain lxd
search lxd
Any ideas as to how I can get the internet working from within the ubuntu:latest Docker-CE container? I’ve tried with several other Docker containers and the result’s always the same - no access to the underlying network whatsoever. In another Alpine-based container with ping preinstalled, I can’t even get a basic ping operation to work:
> ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1): 56 data bytes
ping: can't create raw socket: Permission denied
> ifconfig
ifconfig: socket(AF_INET,2,0): Permission denied
