I am running LXD with the following details:
# lxc info
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: af209b4d143705216083f43aae6cbf9b3f90443b3f473cef481527aa6d071db3
driver: lxc | qemu
driver_version: 5.0.2 | 8.0.0
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "true"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.19.0-45-generic
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Ubuntu
os_version: "22.04"
project: default
server: lxd
server_clustered: false
server_event_mode: full-mesh
server_name: ...
server_pid: 2852889
server_version: "5.14"
storage: zfs | btrfs
storage_version: 2.1.5-1ubuntu6 | 5.16.2
storage_supported_drivers:
- name: cephfs
version: 17.2.5
remote: true
- name: cephobject
version: 17.2.5
remote: true
- name: dir
version: "1"
remote: false
- name: lvm
version: 2.03.11(2) (2021-01-08) / 1.02.175 (2021-01-08) / 4.47.0
remote: false
- name: zfs
remote: false
- name: btrfs
version: 5.16.2
remote: false
- name: ceph
version: 17.2.5
remote: true
Inside of a container, I am using docker with fuse-overlayfs as storage driver. This works quite well, but I found issues with some images. For example ubuntu:16.04 always fails:
# docker run ubuntu:16.04
docker: Error response from daemon: symlink /proc/mounts /var/lib/docker/fuse-overlayfs/2653fe53a0905d2bd4cdac608ca3468c6cb91472f28ae0a48b9bf13743f19ea8-init/merged/etc/mtab: file exists.
See 'docker run --help'.
Interesting is the case with the image http://ghcr.io/gvenzl/oracle-xe:11:
# docker run ghcr.io/gvenzl/oracle-xe:11
CONTAINER: starting up...
Oracle Database SYS and SYSTEM passwords have to be specified at first database startup.
Please specify a password either via the $ORACLE_PASSWORD variable, e.g. '-e ORACLE_PASSWORD=<password>'
or set the $ORACLE_RANDOM_PASSWORD environment variable to any value, e.g. '-e ORACLE_RANDOM_PASSWORD=yes'.
root@t:~/docker-test# docker run ghcr.io/gvenzl/oracle-xe:11
docker: Error response from daemon: symlink /proc/mounts /var/lib/docker/fuse-overlayfs/9ec3cd008b47b7dbde255c06916a9d8ee524e2efa283cec38f218a4fe260b692-init/merged/etc/mtab: file exists.
docker: Error response from daemon: symlink /proc/mounts /var/lib/docker/fuse-overlayfs/fa8ce84ec1220c0f3c0368a2363e84a7f41110686db9e8b0a7d1faf20a1c2177-init/merged/etc/mtab: file exists.
docker: Error response from daemon: symlink /proc/mounts /var/lib/docker/fuse-overlayfs/2f560c6956cfd5025d1f91a55faaa35f758cc57e19f725cdb7ad6d081c4900c2-init/merged/etc/mtab: file exists.
docker: Error response from daemon: symlink /proc/mounts /var/lib/docker/fuse-overlayfs/36b87d3e9f286785587d2f9f9681635e9e236b7705b29f0281f6e92a35c7cc51-init/merged/etc/mtab: file exists.
As you can see, the image sometimes starts correctly and sometimes fails with the same error as ubuntu:16.04.
I tried to update fuse-overlayfs to the latest git master, but this does not change anything.
I then tried to reproduce this issue with a native linux installation and fuse-overlayfs (so without LXD). I was unable to reproduce the issue there.
So at this point I am pretty clueless how this could be solved. Any idea?
Container config:
# lxc config show t
image.architecture: x86_64
image.description: Ubuntu 22.04 LTS server (20230518)
image.os: ubuntu
image.release: jammy
security.nesting: "true"
security.syscalls.intercept.mknod: "true"
security.syscalls.intercept.setxattr: "true"
volatile.base_image: 549a42b59cab0e73421759479633d5a9356f6dea2ff1f26c9ff52bf6fc59e6ef
volatile.cloud-init.instance-id: bb487f92-3799-4867-9452-24d2c395f91e
volatile.eth0.host_name: veth910164a6
volatile.eth0.hwaddr: 00:16:3e:bb:12:db
volatile.idmap.base: "0"
volatile.uuid: d1e63f13-770e-4e31-96cf-82939b6fc10e
volatile.uuid.generation: d1e63f13-770e-4e31-96cf-82939b6fc10e
devices: {}
