hey, @stgraber , u a cool guy, but ur last posts makes me sad more and more
Yeah, i googled many examples running docker in LXD, but i can’t use LXD cuz i strongly need to have containers configs as files so i have to use LXC. Well, maybe someone else have good experience with docker and LXC…
You can probably replicate what LXD does, but that means manually generating your apparmor profiles, loading them with apparmor namespacing, making sure to be on a compatible filesystem and if the container is unprivileged, then you’ll also need to write a service which handles syscall interception for mknod and setxattr or you’ll have some surprises with some layers.
You can query the LXD database using SQL statements but I am unaware of using SQL to manage a LXD container. In fact, such a thing would really be hardcore.
There is this addon for LXC on Puppet 3.0, https://forge.puppet.com/sjimenez/lxc/readme
Last updated in 2015, developed on Ubuntu 14.04 for Puppet 3.0.
Is this the one you are currently using?
Someone did something with LXD and Puppet, https://github.com/jhughes01/lxd-puppet
What you need is support for LXD in Puppet.
Can you frame what is needed to get proper support for LXD in Puppet?
No i can’t, cuz it’s very bad practice manage something with Puppet through SQL, it should be configs as files, stateful files. I don’t want to use LXC puppet module from forge, i will write it by myself. I have a lot of experience with that.
Ok, lxc launch images:centos/7/amd64 centos7-5 so where i can find now config of this container?
If i create container with lxc-create -t download -n centos7-4 -B lvm --vgname vg1 --fssize 5G --fstype ext4 -- -d centos -r 7 -a amd64 i am quite sure exactly, there is stateful /var/lib/lxc/centos7-4/config who can be managed with Puppet or something else. So, i don’t need to create containers with YAML like this lxc launch images:centos/7/amd64 centos7-5 < my_config.yaml , i need to have stateful config of that container
You asked a very specific question and got the corresponding answer.
There was no background as to what you are trying to do.
LXD maintains maintains the configuration in a SQL database,
and your question was phrased about changing the architecture of the whole project.
You, as a user, are not directly accessing the SQL database in any case.
The access is through the LXD REST API.
The lxc client is using this REST API to communicate with the LXD server.
The robust way to support LXD in Puppet is to use directly the REST API, or if you are really inclined, through the lxc client).
ohh, i never asked “about changing the architecture of the whole project”. I’m just find the ways, but i already saw - there are not. To teach Puppet to use LXD REST API - bad way, bad practice, only one simple and good choice - use files as it in LXC, but I have long understood (many posts ago) - it isn’t possible. So i’m just tried to be clarify and explain you, why i have to use LXC instead of LXD, that’s all…
I could accept that you probably did not intend to ask an architecture change.
You say that using the LXD REST API is “bad way, bad practice”. This is certainly not the case.
It might be more difficult for someone who is familiar with something else and would require to learn more new things, but it is definitely not bad way, bad practice.
I think it looks like holywar now. I never didn’t asked about how to: “use LXD REST API”, “how to convert lxc-create to something”, etc. And yes, it’s realy bad way, bad practice use LXD REST API with Puppet cuz Puppet haven’t provider that, he is can only manage config files cuz it’s universal method. Anyway, how this all refers to the main topic where i’m just want to run docker over LXC? I already found out from @stgraber there is no simple way to do that only if use LXD API. Why you repeat it from post to post?
simos only wanted to help you.
And your english doesn’t really make it easy to understand what you are about.
And I don’t really understand your problem.
If we take aside the puppet aspect:
You can easily manage everything through lxd.
You can look at the configs via commands, change the configs via commands and you can automatize the use of configs by creating profiles.
