I’ve set up a nginx container (linuxserver SWAG) in docker, inside a LXD Opensuse Tumbleweed container. It is working ok, I can access my services from outside.
My problem is that I’m not able to identify the origin of any petition, because nginx always “sees” the same ip: 172.18.0.1 (the docker default bridged network).
If I run docker outside the LXD container, in the host, nginx “sees” the real ip that originates the petition.
After launching the container, I’ve done this:
lxc config set t1 security.nesting=true security.syscalls.intercept.mknod=true security.syscalls.intercept.setxattr=true
lxc network attach lxdbr0 t1 eth0
lxc config device set t1 eth0 ipv4.address 192.168.5.101
lxc restart t1
lxc config device add t1 p443 proxy listen=tcp:0.0.0.0:443 connect=tcp:127.0.0.1:443`
The YAML for the nginx docker container has cap_add: - NET_ADMIN
. Just to let you know.
Then installed docker and created the container for nginx and configured it. As said, it works, but it doesn’t log/“sees” the right origin ip’s.
What am I missing? Do you need some more information to help me?
