Hello. I’m just migrated from LXD (see Migrating from LXD 6.1? - #2 by simos)
I’m not able to make docker containers into my incus container to work with my GPU.
This was discussed here: Incus, docker and NVIDIA GPU - #6 by C0rn3j and I’ve been working like this in LXD: lxd container configured like this:
I’ve recreated the Incus containers because I suffered a strange docker failure after migration (docker cant run because of some kernel modules, see the post of my migration)
image.architecture: amd64
image.description: Rockylinux 9 amd64 (20240830_02:06)
image.os: Rockylinux
image.release: "9"
image.requirements.cdrom_agent: "true"
image.serial: "20240830_02:06"
image.type: squashfs
image.variant: default
raw.idmap: both 1000 1000
security.nesting: "true"
security.syscalls.intercept.mknod: "true"
security.syscalls.intercept.setxattr: "true"
volatile.base_image: b535a4a982ade5ecbf8e2926f5704d4bc9a268f59d2965517fa95cc5adda0f1c
volatile.cloud-init.instance-id: a5d1c5ed-0d50-4849-9d3c-d274eb1039df
volatile.eth0.host_name: vethcb9cf0e0
volatile.eth0.hwaddr: 00:16:3e:a3:ea:75
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001001,"Nsid":1001,"Maprange":64535},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":false,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":64535}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":true,"Isgid":true,"Hostid":1000,"Nsid":1000,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001001,"Nsid":1001,"Maprange":64535},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000},{"Isuid":false,"Isgid":true,"Hostid":1001001,"Nsid":1001,"Maprange":64535}]'
volatile.uuid: dc48cdeb-04dc-4eae-8eb1-f53ea8fce22d
volatile.uuid.generation: dc48cdeb-04dc-4eae-8eb1-f53ea8fce22d
path: /mnt/whishper
source: /mnt/main/docker/whishper
gpu:
type: gpu
Installed nvidia driver into the container, and so nvidia-container-toolkit.
In the rocky container /etc/docker/daemon.json configured for the nvidia runtime too.
I need to set “no-cgroups = true”in the Nvidia docker config file./etc/nvidia-container-runtime/config.toml`
And it worked.
Now the docker containers are not able to access gpu. The strange thing for me is that I can run nvidia-smi in the incus container, AND in the docker container, and it works!
Could you see what am I doing wrong?
