Scott_T
(Scott T)
July 25, 2024, 11:02pm
1
@stgraber What does this error mean and how can I correct it?
scott demo-1 ~ incus launch docker:jgraph/drawio Draw-3
scott demo-1 ~ incus profile create proxy-8080
Profile proxy-8080 created
scott demo-1 ~ incus profile device add proxy-8080 hostport8080 proxy connect="tcp:127.0.0.1:8080" listen="tcp:0.0.0.0:8080"
Device hostport8080 added to proxy-8080
scott demo-1 ~ incus profile add Draw-3 proxy-8080
Error: Failed to start device "hostport8080": Error occurred when starting proxy device: Error: Permission denied - Failed setns to connector network namespace
stgraber
(Stéphane Graber)
July 26, 2024, 7:21pm
2
No idea, I’ve had no luck reproducing this error here so far.
Maybe look at dmesg
for any DENIED
entries?
Apparmor in Ubuntu 24.04’s stock kernel is really weird and broken in a few ways…
Scott_T
(Scott T)
July 26, 2024, 8:50pm
3
I just discovered that
security.privileged=true
fixed this. Does that explain anything?
stgraber
(Stéphane Graber)
July 26, 2024, 10:43pm
4
Not really and that’s likely a very bad idea
Though privileged fixing it may make it more likely to be a subtle apparmor issue on Ubuntu.
Scott_T
(Scott T)
July 26, 2024, 10:49pm
5
Yes, I am aware. Not what I wanted to do.
Scott_T
(Scott T)
July 26, 2024, 11:01pm
6
If I have two OCI containers running on the default incus NAT, how would I get say a sql container to talk to an app? Is it like docker where the container names themselves allows for the connection?
stgraber
(Stéphane Graber)
July 27, 2024, 1:27am
7
NAME.incus
should work fine
Scott_T
(Scott T)
July 27, 2024, 2:29am
8
I am not sure that I understand. Can you give me an example? If I have a docker compose file with an app container and a sql container I might have a depends_on directive. Is NAME.incus a -c switch for the container?
stgraber
(Stéphane Graber)
July 27, 2024, 2:38am
9
We don’t have dependencies but we have working DNS.
stgraber@dakara:~$ incus launch images:ubuntu/24.04 c1
Launching c1
stgraber@dakara:~$ incus launch images:ubuntu/24.04 c2
Launching c2
stgraber@dakara:~$ incus exec c2 bash
root@c2:~# ping c1.incus -c1
PING c1.incus (2602:fc62:c:250:216:3eff:fe7e:3ab8) 56 data bytes
64 bytes from c1.incus (2602:fc62:c:250:216:3eff:fe7e:3ab8): icmp_seq=1 ttl=64 time=0.084 ms
--- c1.incus ping statistics ---
rtt min/avg/max/mdev = 0.084/0.084/0.084/0.000 ms
root@c2:~#
