`docker stat` inside Incus container
Hello.
I’m trying to run Docker inside Incus container (Linux Gentoo on host and guest) with cgroupv2 environment. Generally it’s runs fine except inability to get metrics from docker containers like docker stats does. After investigation I found that docker unable to read some cgroupv2 metrics, which cannot be created due empty /sys/fs/cgroup/cgroup.subtree_control in container. In console.log I see that guest’s cgroup init-script cannot runs properly:
 * Caching service dependencies ... [ ok ]
mount: /sys/fs/cgroup: none already mounted on /dev.
       dmesg(1) may have more information after failed mount system call.
/etc/init.d/cgroups: line 92: echo: write error: Device or resource busy
where line 92 is:
        case "${rc_cgroup_mode:-unified}" in
                unified)
                        echo "+${x}"  > "${cgroup_path}/cgroup.subtree_control" # << line 92
I cannot change it manually too:
echo "+memory" > /sys/fs/cgroup/cgroup.subtree_control
-bash: echo: write error: Device or resource busy
How I can override this behavior? On Debian guest (systemd) docker stats runs fine.
Here info about my setup:
incus info
  core.https_address: 192.168.1.3:8443
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
- instance_memory_swap_bytes
- network_bridge_external_create
- network_zones_all_projects
- storage_zfs_vdev
- container_migration_stateful
- profiles_all_projects
- instances_scriptlet_get_instances
- instances_scriptlet_get_cluster_members
- instances_scriptlet_get_project
- network_acl_stateless
- instance_state_started_at
- networks_all_projects
- network_acls_all_projects
- storage_buckets_all_projects
- resources_load
- instance_access
- project_access
- projects_force_delete
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: root
auth_user_method: unix
environment:
  addresses:
  - 192.168.1.3:8443
  architectures:
  - x86_64
  - i686
  certificate: |
    -----BEGIN CERTIFICATE-----
    MIIB/zCCAYagAwIBAgIQaxqcwCCnksnPxHRUCIZ2ajAKBggqhkjOPQQDAzAyMRkw
    FwYDVQQKExBMaW51eCBDb250YWluZXJzMRUwEwYDVQQDDAxyb290QGljZXdpbmQw
    HhcNMjQwMjA5MTQ0NjE0WhcNMzQwMjA2MTQ0NjE0WjAyMRkwFwYDVQQKExBMaW51
    eCBDb250YWluZXJzMRUwEwYDVQQDDAxyb290QGljZXdpbmQwdjAQBgcqhkjOPQIB
    BgUrgQQAIgNiAAQG49vVljkunxmdk4h44TbveNXOMO4HiAGdk49ogpIFC6EKJi7E
    BMj8NdXzMlCyCMd0LMKduP8vM2zEhpCcGxhlGwhOKBWN0qOd8kNroH7tTv2sCLjT
    eoxqSZqKNUiSOP2jYTBfMA4GA1UdDwEB/wQEAwIFoDATBgNVHSUEDDAKBggrBgEF
    BQcDATAMBgNVHRMBAf8EAjAAMCoGA1UdEQQjMCGCB2ljZXdpbmSHBH8AAAGHEAAA
    AAAAAAAAAAAAAAAAAAEwCgYIKoZIzj0EAwMDZwAwZAIwTXeWmV97WDkJj1CieG6m
    XUtS+qPq1zyW4tsawXKT8aa+y46HOs5+nhnx2LRwtvWtAjBu0/b0T9Fq7VMlLT67
    TfQAizrkVbT9hh/OQ+oMj7laEmlLZMIZQ5NgkfJ0KUjQWGc=
    -----END CERTIFICATE-----
  certificate_fingerprint: 5a97aab64075d37b699224c332c3f27ae229ef71764ba9bc3cc27e6711d1832f
  driver: qemu | lxc
  driver_version: 8.2.3 | 6.0.0
  firewall: xtables
  kernel: Linux
  kernel_architecture: x86_64
  kernel_features:
    idmapped_mounts: "true"
    netnsid_getifaddrs: "true"
    seccomp_listener: "true"
    uevent_injection: "true"
    unpriv_binfmt: "false"
    unpriv_fscaps: "true"
  kernel_version: 6.6.30-gentoo-x86_64
  lxc_features:
    cgroup2: "true"
    core_scheduling: "true"
    devpts_fd: "true"
    idmapped_mounts_v2: "true"
    mount_injection_file: "true"
    network_ipvlan: "true"
    network_l2proxy: "true"
    network_veth_router: "true"
    pidfd: "true"
    seccomp_notify: "true"
  os_name: Gentoo
  os_version: "2.15"
  project: default
  server: incus
  server_clustered: false
  server_event_mode: full-mesh
  server_name: icewind
  server_pid: 17894
  server_version: "6.2"
  storage: zfs
  storage_version: 2.2.4-r0-gentoo
  storage_supported_drivers:
  - name: zfs
    remote: false
  - name: dir
    version: "1"
    remote: false
  - name: lvm
    version: 2.03.22(2) (2023-08-02) / 1.02.196 (2023-08-02) / 4.48.0
    remote: false
  - name: lvmcluster
    remote: true
incus config show g1
  image.architecture: amd64
  image.description: Gentoo current amd64 (20240709_16:07)
  image.os: Gentoo
  image.release: current
  image.requirements.secureboot: "false"
  image.serial: "20240709_16:07"
  image.type: squashfs
  image.variant: openrc
  raw.lxc: lxc.mount.auto = cgroup:rw:force
  security.nesting: "true"
  security.privileged: "true"
  security.syscalls.intercept.mknod: "true"
  security.syscalls.intercept.mount: "true"
  volatile.base_image: b00726eb7a90d356d77b844cf83336f74136f7e94c7c45b320b6a53cc9dcde38
  volatile.cloud-init.instance-id: e19dca40-ea3f-4f90-8b94-430bbb39fc8f
  volatile.eth0.host_name: vethda61399b
  volatile.eth0.hwaddr: 00:16:3e:0c:18:aa
  volatile.idmap.base: "0"
  volatile.idmap.current: '[]'
  volatile.idmap.next: '[]'
  volatile.uuid: 034bd6d5-76a4-4bc4-a2b7-5b806dfe9352
  volatile.uuid.generation: 034bd6d5-76a4-4bc4-a2b7-5b806dfe9352
devices: {}
It’s not something that we’re controlling on our end, so most likely you’d need to edit that init script.
I can’t figure out, why in container I can’t override /sys/fs/cgroup/cgroup.subtree_control? Is there some restrictions from LXC that I can change?
I’ve tried Alpine (also OpenRC based distributive), and there same error.
It’s most likely a security check in the kernel that prevents unprivileged users from turning controllers on/off.
Appears that this is OpenRC issue described here: OpenRC breaks cgroups resource accounting with cgroups v2 for an Incus/LXC container · Issue #1013 · OpenRC/openrc · GitHub .
Let’s hope that will be fixed in next release.
