lxd create vitual-machine
Yes you can add a disk device using lxc config device add <instance> <device name> disk source=/path/to/iso/file
thanks.Can LxC image list import ISO image source?
No not directly.
But if you create a VM by booting from an ISO as described above, then once you’re happy with its setup, you can publish the VM as an image using lxc publish.
