I had great success deploying the juju charm to a manually installed LXD host.
juju deploy lxd --num-units 1 --config snap-channel="5.0/stable" --config lxd-listen-https=true --config lxd-listen-metrics=true --config lxd-preseed="$(cat preseed.yaml) --to 0"
So, my question is if the charm does per default the production grade config as described here: Production setup - LXD documentation
The documentation of the charm doesn’t tell.
Thanx for a great experience so far with LXD and the Juju charm that comes with it.
I use the following setup taken from the above and I can see a few differences: https://github.com/erik78se/mydocs/blob/main/lxd/production-setup.md
This is what I found on the host, but I’m not sure if that comes from the charm:
cat /etc/sysctl.d/60-lxd.conf
fs.aio-max-nr = 524288
fs.inotify.max_queued_events = 1048576
fs.inotify.max_user_instances = 1048576
fs.inotify.max_user_watches = 1048576
kernel.dmesg_restrict = 1
kernel.keys.maxbytes = 2000000
kernel.keys.maxkeys = 2000
net.ipv4.neigh.default.gc_thresh3 = 8192
net.ipv6.neigh.default.gc_thresh3 = 8192
vm.max_map_count = 262144
