I am trying to get a full list of images for both containers and virtual machines, normally I send a GET request to https://images.linuxcontainers.org:8443 however the virtual machine images are not showing up.
For example image Ubuntu focal arm64 with fingerprint fc9938212e49 is not on that list.
Please can you point me in the right direction. Thanks.
We consider https://images.linuxcontainers.org:8443 to be legacy. LXD these days uses simplestreams with most of its public image servers as that’s a lot less hackish than having to pretend to implement a rest api on a static web server
That is even easier, is that now the official way to do this? I am mean can I implement this safely in an application without worrying about it breaking (asking because it seems strange that the JSON is just waiting for me).
When running lxc launch images:ubuntu/focal u2, how does LXC determine which version, looking at the contents of the file, LXC is not using the latest, is there a reason for that? I am just trying to determine which fingerprint to use.
Also if i am understanding the format correctly, combined_squashfs_sha256 refers to the fingerprint for a container and combined_disk-kvm-img_sha256 is for a virtual machine.
LXD is supposed to pull the latest image though note that LXD itself has a simplestreams cache to avoid needlessly re-downloading the index so there may be a bit of latency.
You can use lxc image info images:whatever to query directly without any caching.
Here I’m seeing:
stgraber@castiana:~$ lxc image info images:ubuntu/focal
Fingerprint: bd999bbcba6fb30952d60c96f40008781092b6d9a1be32c475bcef98369f422f
Type: container
Public: yes
Timestamps:
Created: 2021/06/18 00:00 UTC
Uploaded: 2021/06/18 00:00 UTC
Expires: never
Last used: never
Properties:
description: Ubuntu focal amd64 (20210618_07:42)
variant: default
os: Ubuntu
release: focal
architecture: amd64
serial: 20210618_07:42
type: squashfs
Aliases:
- ubuntu/focal/default
- ubuntu/focal/default/amd64
- ubuntu/20.04/default
- ubuntu/20.04/default/amd64
- ubuntu/focal
- ubuntu/focal/amd64
- ubuntu/20.04
- ubuntu/20.04/amd64
Cached: no
Auto update: disabled
Profiles: []
stgraber@castiana:~$ lxc image info images:ubuntu/focal --vm
Fingerprint: acd2a4331c42385991815083a8fc2547257abe7c037ff64b11cc7afd05bbd566
Type: virtual-machine
Public: yes
Timestamps:
Expires: never
Last used: never
Properties:
os: Ubuntu
release: focal
variant: default
architecture: amd64
type: disk-kvm.img
Aliases:
- ubuntu/focal
- ubuntu/20.04
Cached: no
Profiles: []
Thats fine, thanks for explaining, my gut reaction was to download the latest, but i was wondering why that was not happening in LXD, so obviously the cache is too blame. The version you showed there, is from 3 days ago, there were two updates since then. Thank you very much.
Sorry for the confusion, it is not your response that is cached from a few days ago, but on one my installations. I am getting the b2bb76a83d4c fingerprint which is from 20210616_07:42.
