'du -h' vs 'df -h' difference
I am using lxc 5.0.1 on ubuntu 22.04, along with a NFS . The problem I am facing is that while my ‘df -h’ shows 100% usage on root directory, 'du -x -h ' shows only 13%. I tried several things, which I found on mostly StackOverflow, could not succeed to successfully investigate the issue.
Output of ‘df -h’
while output of ‘du -s * | sort -n -r | more’ in text
8388612 swap.img
2951952 usr
1400128 snap
809784 var
252212 boot
176916 run
5808 etc
92 home
48 tmp
16 lost+found
4 user1
4 ssl
4 srv
4 root
4 opt
4 mnt
4 media
0 sys
0 sbin
0 proc
0 libx32
0 lib64
0 lib32
0 lib
0 dev
0 bin
Please help me to solve this issue
Hi @manmatha-roy
df -h uses statfs syscall to obtain information about filesystem like number of data blocks, number of free blocks and so on. It uses this information to calculate Size / Used / Avail values.
While du -s uses fstatat syscall to on each file/dir during traversal of tree and then sum values.
Possible problem here is that you have some processes that holds file descriptors to big files from the root filesystem and this files was unlinked (so, they don’t exist in filesystem tree, but in fact they stored in the filesystem). You can try to reboot your machine and if this helps then it is. As an alternative to reboot you can try to reload some services in your system those most probably cause this, like systemd-journald.
@amikhalitsyn
Thanks. What I found is that some lxd vm volumes are missing.
Jan 19 22:57:14 host-15 lxd.daemon[168861]: time=“2023-01-19T22:57:14+05:30” level=warning msg=“Error getting disk usage” err=“Failed to run: zfs get -H -p -o value used cssc-it-service-1/virtual-machines/roundecube-database-server.block: exit status 1 (cannot open ‘cssc-it-service-1/virtual-machines/roundecube-database-server.block’: dataset does not exist)” instance=roundecube-database-server instanceType=virtual-machine project=default
Possibly, as this volume was missing, all diskwrite request to this volume was piling up and creating df vs du difference.
Now the new problem is that how this volume went missing. I really dont have any clue.
please, show cat /proc/1/mountinfo from the host. Tell us a little bit more about your setup. Is it a new node (and new problem) or it’s an old setup and problem is appeared recently?
@amikhalitsyn
Sorry for being naive, in earlier post.
Here is my cat /proc/1/mountinfo
24 30 0:22 / /sys rw,nosuid,nodev,noexec,relatime shared:7 - sysfs sysfs rw
25 30 0:23 / /proc rw,nosuid,nodev,noexec,relatime shared:12 - proc proc rw
26 30 0:5 / /dev rw,nosuid,relatime shared:2 - devtmpfs udev rw,size=1056604824k,nr_inodes=264151206,mode=755,inode64
27 26 0:24 / /dev/pts rw,nosuid,noexec,relatime shared:3 - devpts devpts rw,gid=5,mode=620,ptmxmode=000
28 30 0:25 / /run rw,nosuid,nodev,noexec,relatime shared:5 - tmpfs tmpfs rw,size=211332328k,mode=755,inode64
30 1 253:0 / / rw,relatime shared:1 - ext4 /dev/mapper/ubuntu--vg-ubuntu--lv rw
31 24 0:6 / /sys/kernel/security rw,nosuid,nodev,noexec,relatime shared:8 - securityfs securityfs rw
32 26 0:27 / /dev/shm rw,nosuid,nodev shared:4 - tmpfs tmpfs rw,inode64
33 28 0:28 / /run/lock rw,nosuid,nodev,noexec,relatime shared:6 - tmpfs tmpfs rw,size=5120k,inode64
34 24 0:29 / /sys/fs/cgroup rw,nosuid,nodev,noexec,relatime shared:9 - cgroup2 cgroup2 rw
35 24 0:30 / /sys/fs/pstore rw,nosuid,nodev,noexec,relatime shared:10 - pstore pstore rw
36 24 0:31 / /sys/fs/bpf rw,nosuid,nodev,noexec,relatime shared:11 - bpf bpf rw,mode=700
37 25 0:32 / /proc/sys/fs/binfmt_misc rw,relatime shared:13 - autofs systemd-1 rw,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15335
38 26 0:33 / /dev/hugepages rw,relatime shared:14 - hugetlbfs hugetlbfs rw,pagesize=2M
39 26 0:20 / /dev/mqueue rw,nosuid,nodev,noexec,relatime shared:15 - mqueue mqueue rw
40 24 0:7 / /sys/kernel/debug rw,nosuid,nodev,noexec,relatime shared:16 - debugfs debugfs rw
41 24 0:12 / /sys/kernel/tracing rw,nosuid,nodev,noexec,relatime shared:17 - tracefs tracefs rw
42 24 0:34 / /sys/fs/fuse/connections rw,nosuid,nodev,noexec,relatime shared:18 - fusectl fusectl rw
43 24 0:21 / /sys/kernel/config rw,nosuid,nodev,noexec,relatime shared:19 - configfs configfs rw
65 28 0:35 / /run/credentials/systemd-sysusers.service ro,nosuid,nodev,noexec,relatime shared:20 - ramfs none rw,mode=700
89 30 8:2 / /boot rw,relatime shared:30 - ext4 /dev/sda2 rw
92 30 7:0 / /snap/core20/1738 ro,nodev,relatime shared:45 - squashfs /dev/loop0 ro,errors=continue
95 30 7:1 / /snap/core20/1778 ro,nodev,relatime shared:47 - squashfs /dev/loop1 ro,errors=continue
98 30 7:2 / /snap/lxd/22923 ro,nodev,relatime shared:49 - squashfs /dev/loop2 ro,errors=continue
101 30 7:3 / /snap/lxd/23541 ro,nodev,relatime shared:51 - squashfs /dev/loop3 ro,errors=continue
104 30 7:4 / /snap/snapd/17883 ro,nodev,relatime shared:53 - squashfs /dev/loop4 ro,errors=continue
107 30 7:5 / /snap/snapd/17950 ro,nodev,relatime shared:55 - squashfs /dev/loop5 ro,errors=continue
110 28 0:36 / /run/rpc_pipefs rw,relatime shared:57 - rpc_pipefs sunrpc rw
113 37 0:37 / /proc/sys/fs/binfmt_misc rw,nosuid,nodev,noexec,relatime shared:59 - binfmt_misc binfmt_misc rw
586 28 0:25 /snapd/ns /run/snapd/ns rw,nosuid,nodev,noexec,relatime - tmpfs tmpfs rw,size=211332328k,mode=755,inode64
609 586 0:4 mnt:[4026534947] /run/snapd/ns/lxd.mnt rw - nsfs nsfs rw
741 30 0:55 / /var/snap/lxd/common/lxd/disk_nfs rw,relatime shared:327 - nfs 192.168.54.185:/ifs/docker/cisco-143.15 rw,vers=3,rsize=131072,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.54.185,mountvers=3,mountport=300,mountproto=udp,local_lock=none,addr=192.168.54.185
614 28 0:44 / /run/user/1000 rw,nosuid,nodev,relatime shared:325 - tmpfs tmpfs rw,size=211332324k,nr_inodes=52833081,mode=700,uid=1000,gid=1000,inode64
Setup: I am using lxd vm on top of ubuntu 22.04 host with nfs as main storage. zfs pools are residing on nfs.
Problem: There was a huge gap between du and df and it kept on increasing. Finally when df did hit 100% disk usage , containers become unresponsive. Though the host itself seemed to be fine. Then I restarted the host, which apparently fixed the du vs df anamoly. but could not start lxd containers, as it appears that appropriate volumes are missing in zpool.
root@host-15:/# zpool list
NAME                SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
cssc-it-service-1  1.36T   652K  1.36T        -      496G     0%     0%  1.00x    ONLINE  -
and
root@host-15:/# zfs list
NAME        USED  AVAIL     REFER  MOUNTPOINT
cssc-it-service-1        652K  1.32T       24K  legacy
cssc-it-service-1/containers        24K  1.32T       24K  legacy
cssc-it-service-1/custom        24K  1.32T       24K  legacy
cssc-it-service-1/deleted        120K  1.32T       24K  legacy
cssc-it-service-1/deleted/containers        24K  1.32T       24K  legacy
cssc-it-service-1/deleted/custom        24K  1.32T       24K  legacy
cssc-it-service-1/deleted/images        24K  1.32T       24K  legacy
cssc-it-service-1/deleted/virtual-machines                                                               24K  1.32T       24K  legacy
cssc-it-service-1/images        24K  1.32T       24K  legacy
cssc-it-service-1/virtual-machines        24K  1.32T       24K  legacy
but
there should at least 4 lxc vm, as being shown there in lxc list.
If I try to start them, , it is showing error
Error: Failed to run: zfs get -H -p -o value volmode cssc-it-service-1/virtual-machines/computational-nis-server.block: exit status 1 (cannot open 'cssc-it-service-1/virtual-machines/computational-nis-server.block': dataset does not exist
while lxc info shows
Error: open /var/snap/lxd/common/lxd/logs/computational-nis-server/qemu.log: no such file or directory
Please guide me to resoolve this issue?
[Do you want me to create a new thread, or this will work?]
@manmatha-roy please show lxc storage list too. Have you used ZFS on top of loop device?
