elvis.chen
(Elvis Chen)
February 14, 2023, 10:39am
1
Hi LXD users,
We’re trying to setup the DNS on a lxdbr0 bridge with DHCP enabled. And then publish the DNS information to another DNS server.
Here is the config for the network zone (ip info hidden)
peers.xxx.address: 7.7.7.7
used_by: []
Here is the relavant config for the network lxdbr0 (ip info hidden)
bridge.mtu: "1500"
dns.zone.forward: pvn.lxd
ipv4.address: 11.11.11.0/24
ipv4.dhcp: "true"
ipv4.dhcp.expiry: 1d
ipv4.dhcp.ranges: 11.11.11.11 - 11.11.11.111
ipv4.nat: "false"
ipv6.address: none
Since the DNS information comes from the DHCP leases, I did lxc network list-leases lxdbr0
| vm1 | 00:16:3e:fe:65:ac | 11.11.11.12 | DYNAMIC | lxd-cluster0|
| vm1 | 00:16:3e:fe:65:ac |11.11.11.12 | DYNAMIC | lxd-cluster1|
| vm1 | 00:16:3e:fe:65:ac | 11.11.11.12 | DYNAMIC | lxd-cluster2|
| vm1 | 00:16:3e:fe:65:ac | 11.11.11.12 | DYNAMIC | lxd-cluster3|
| vm1 | 00:16:3e:fe:65:ac | 11.11.11.12 | DYNAMIC | lxd-cluster4|
| vm1 | 00:16:3e:fe:65:ac | 11.11.11.12 | DYNAMIC | lxd-cluster5|
We found that the leases is repeated once for each member in the cluster. And therefore creating multiple entries in the DNS.
I’m wondering is this an expected behavior to sync the lease?
tomp
(Thomas Parrott)
February 14, 2023, 10:54am
2
Please can you show lxc config show <instance> --expanded for vm1?
And also please confirm that vm1 only exists on one cluster member?
tomp
(Thomas Parrott)
February 14, 2023, 11:29am
3
What version of LXD is this?
elvis.chen
(Elvis Chen)
February 15, 2023, 2:10am
4
The lxd version is 5.10.
I can make sure this instance only exists in one machine.
Here is the lxc config show -e
image.architecture: amd64
image.description: Ubuntu jammy amd64 (20221115_07:42)
image.os: Ubuntu
image.release: jammy
image.serial: "20221115_07:42"
image.type: disk-kvm.img
image.variant: cloud
limits.cpu: "10"
limits.memory: "161061273600"
security.secureboot: "false"
volatile.base_image: ec5544c7adf0ec0ec4cc6fb2ad53ae0b516acbb9f23a8ba7aede3b54352e419a
volatile.cloud-init.instance-id: f8ebe8c9-55d2-4233-9e62-9ec2ca468e79
volatile.eth0.host_name: tapf0456408
volatile.eth0.hwaddr: 00:16:3e:a3:7f:b6
volatile.uuid: 4f620e86-3e4d-4e7d-8663-11bc53a43dba
volatile.vsock_id: "166"
boot.priority: "1"
ipv4.routes.external: 11.11.11.12/32
network: lxdbr0
Also we’re using netplan to manage some of the network settings. It might be helpful
# /etc/netplan/50-cloud-init.yaml
network:
ethernets:
enp5s0:
dhcp4: true
match:
macaddress: 00:16:3e:a3:7f:b6
mtu: 1500
nameservers:
addresses:
- 8.8.8.8
search:
- maas
set-name: enp5s0
version: 2
tomp
(Thomas Parrott)
February 15, 2023, 8:11am
5
Can you show me output of lxc list --all-projects please
tomp
(Thomas Parrott)
February 15, 2023, 8:12am
6
OK so its possibly and issue with routes external setting.
Do you have multiple instances with the same route on their NIC out of interest?
tomp
(Thomas Parrott)
February 15, 2023, 8:50am
8
Can you also confirm you’re not using the same MAC address with multiple instances?
elvis.chen
(Elvis Chen)
February 17, 2023, 9:49am
10
Sorry I can’t show you everything due to confidentiality. I can show the list of only this machine
$ lxc list --all-projects vm1
| PROJECT | NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS | LOCATION |
| pvn | vm1 | RUNNING | 11.11.11.12 (enp5s0) | | VIRTUAL-MACHINE | 0 | lxd-cluster1|
No, these addresses are assigned by lxdbr0 DHCP and are unique across all projects.
Yes, this address is auto assigned as well. I double checked this using lxc list -f compact -c volatile.eth0.hwaddr --all-projects | uniq -c, which gives me all 1s. (All of our network devices are named eth0).
I’ve been able to change this by manually editing the lease file /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases. However, it seems this will pop up again after some leases renewals.
Also I want to point out that this is not happening for all the VMs, only certain ones. And the entries may only repeat for a fraction of the cluster members. For example, 5 out of 20. However I’ve been unable to tell the difference between these machines and others.
BTW, is this possibly due to unsynced time between the cluster? There are indeed time differences between the machines in the magnitudes of seconds, or even > 10secs.
