Empty pages in operations-centre web ui
just installed a new 3-node IncusOS cluster with operations-center 202609222152.
Web GUI is working fine except several pages where URL is starting /ui/inventory/*.
They are displayed for 1/50 sec correctly and then displayed as white empty page.
My browsers are Firefox on linux and win11 and chrome on win11.
Is it my fault or is there a bug?
Thank you
Most likely a bug. Can you go check your browser’s debug console from the developer tools?
You can usually get that by pressing F12
Firefox 156.0.1
Chrome 154.0.8037.58
Uncaught TypeError: URL constructor: is not a valid URL.
sa https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:65
nm https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
xm https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
sx https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
Mx https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
bk https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
zm https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
Ex https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
Vx https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
Cc https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
qx https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
Ek https://192.168.1.100:8443/ui/assets/index-DlutoO5v.js:48
index-DlutoO5v.js:65:13905
@presztak @breml can one of you look into this?
I’ll take a look, I guess this is UI issue.
@kri164 , did you fill in the connection URL field when creating the cluster, or leave it empty?
I cant remember, sorry.
Will try to rebuild from scratch and report.
Thank you for help.
  1. září 2026 15:52:34 UTC, Piotr Resztak noreply@discuss.linuxcontainers.org napsal:
No worries, we’ve introduced two fixes:
