Edit: solved—see comments below.
I have attempted to configure Incus to use an existing, encrypted ZFS dataset as its default storage pool. I had configured ZFS to automatically unlock and mount both the zpool and the dataset on boot. After running incus admin init and selecting the dataset to use for the default storage pool, the dataset no longer mounts on boot and it isn’t available for use by Incus. In addition, many Incus commands fail with [solved—see below]Error: The remote isn't a private server which is confusing because I don’t think I’m telling it to use a remote.
System Information
Arch Linux
kernel version: LTS 6.6.36
ZFS version: 2.2.4-1
Incus version: 6.2
Setup Details
ZFS and Encryption:
- zpool called
dataand mounted at/data - Encrypted ZFS dataset called
incusand mounted at/data/incus - The dataset automounts via
zfs-mount.service - The key for the dataset is provided by a custom service:
zfs-load-key@.servicewhich takes as a parameter thezpool/datasetto load the key for- In this case the parameter will be
data-incus(escaped (%i)) ordata/incus(unescaped (%I)) - Credential is accessed through systemd credentials available in
$CREDENTIALS_DIRECTORYto the service as it runs - the credential is named
zfs-%i-key(in this casezfs-data-incus-key) - the service runs
zfs load-key -L file://${CREDENTIALS_DIRECTORY}/zfs-%i-key %I - The service is configured
AfterandRequireszfs-import.target - And
WantedByzfs-mount.service - runs
zfs-loadkey -L file://${CREDENTIALS_DIRECTORY}/zfs-%i-key %I
- The original encryption setup used a keyfile in /tmp which is not available after a reboot, therefore the dataset automounting can only happen if the above service is working properly.
Incus:
- ran
incus admin init - chose to use the existing ZFS dataset
data/incus
Full Preseed from `incus admin init`
config: {}
networks:
- config:
ipv4.address: auto
ipv6.address: auto
type: ""
project: default
storage_pools:
- config:
source: data/incus
driver: zfs
- config: {}
network: incusbr0
pool: default
projects: []
cluster: null
Full config from `incus admin init --dump`
images.auto_update_interval: "0"
networks:
- config:
ipv4.address: redacted
ipv4.nat: "true"
ipv6.address: redacted
ipv6.nat: "true"
type: bridge
project: default
storage_pools:
- config:
source: data/incus
volatile.initial_source: data/incus
zfs.pool_name: data/incus
driver: zfs
- config: {}
network: incusbr0
pool: default
projects:
- config:
features.images: "true"
features.networks: "true"
features.networks.zones: "true"
features.profiles: "true"
features.storage.buckets: "true"
features.storage.volumes: "true"
description: Default Incus project
Other notes:
- Before rebooting, I noticed that several sub-datasets were created under
data/incus:buckets,containers,customand so on - Before
incus admin init, thedata/incusZFS dataset had its mount point set to/data/incusbut after it islegacy - All the sub-datasets have mountpoint
legacy
Tried so far:
- manually mounting the dataset with
zfs mount- fails because the mountpoint is
legacy, says to use genericmountinstead
- redoing
incus admin init- can’t create a storage pool called
defaultbecause it already exists
- deleting the
defaultstorage pool- have to add
--force-localto avoidError: The remote isn't a private server - Fails because the storage pool is currently in use
- have to add
Hypotheses:
- the
zfs-load-keyservice runs after Incus tries to mount the dataset for the storage pool- so I need a different
WantedBy, what could it be?
- need to configure mounts (via
/etc/fstab) for the datasets (to where?) - I should have added the storage pool manually outside of
incus admin init- I could still recreate everything and do this but it’s not obvious that it will help and will be tedious
- Incus shouldn’t have set the mountpoints to
legacyand I should set them back to what they were before
How can I configure Incus to auto-mount an encrypted ZFS dataset for its default storage pool?
