I seem to remember running into similar issues in the past which got tracked down to a systemd bug I believe.
You may want to check if the relevant mount units have been created on boot and if they are, what’s their status. I seem to remember seeing some dependency issue there where an unprivileged container effectively wouldn’t have any of its mount units run.
@brauner not sure if it’s something you ever looked into.
Thanks! I’ve just got the list as shown below and there is no /home2 there. So does it suggest a systemd bug?
root@test:~# systemctl -a | grep mount
proc-sys-fs-binfmt_misc.automount loaded inactive dead Arbitrary Executable File Formats File System Automount Point
-.mount loaded active mounted /
dev-.lxd\x2dmounts.mount loaded active mounted /dev/.lxd-mounts
dev-fuse.mount loaded active mounted /dev/fuse
dev-hugepages.mount loaded active mounted Huge Pages File System
dev-lxd.mount loaded active mounted /dev/lxd
dev-mqueue.mount loaded active mounted POSIX Message Queue File System
dev-net-tun.mount loaded active mounted /dev/net/tun
dev-ptmx.mount loaded active mounted /dev/ptmx
dev-zd0.mount loaded active mounted /dev/zd0
home-share.mount loaded active mounted /home/share
proc-cpuinfo.mount loaded active mounted /proc/cpuinfo
proc-diskstats.mount loaded active mounted /proc/diskstats
proc-meminfo.mount loaded active mounted /proc/meminfo
proc-stat.mount loaded active mounted /proc/stat
proc-swaps.mount loaded active mounted /proc/swaps
proc-sys-fs-binfmt_misc.mount loaded active mounted Arbitrary Executable File Formats File System
proc-sys-net.mount loaded active mounted /proc/sys/net
proc-sysrq\x2dtrigger.mount loaded active mounted /proc/sysrq-trigger
proc-uptime.mount loaded active mounted /proc/uptime
sys-devices-virtual-net.mount loaded active mounted /sys/devices/virtual/net
sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System
sys-kernel-config.mount loaded inactive dead Configuration File System
sys-kernel-debug.mount loaded active mounted Debug File System
● tmp.mount not-found inactive dead tmp.mount
var-lib-lxcfs.mount loaded active mounted /var/lib/lxcfs
● systemd-remount-fs.service loaded failed failed Remount Root and Kernel File Systems
umount.target loaded inactive dead Unmount All Filesystems
