I am using the LXD api to write a Hashicorp Packer plugin (https://github.com/deepankarsharma/packer-plugin-lxdapi). The lxc Go api has been pleasant to use and I have been able to get things to a point where I can write things like the following and have packer generate a valid LXD container or VM image.
source "lxdapi" "instance" {
unix_socket_path = "/var/snap/lxd/common/lxd/unix.socket"
source_image = "jammy-amd64"
output_image = "jammy-output"
output_image_description = "Jammy container image"
publish_properties = {
config = {
"security.secureboot": "false"
virtual_machine = false
compression_algorithm = "zstd"
build {
sources = [
"source.lxdapi.instance",
provisioner "lxdapi-shell" {
environment = {
"HELLO": "WORLD"
inline = [
"env",
"echo $HELLO",
I am now trying to add support for environment variables in the call to ExecInstance (https://github.com/deepankarsharma/packer-plugin-lxdapi/blob/main/utils/lxd_utils.go#L272).
Am using the following simple use case to test environment variables. The underlying code adds HELLO=WORLD to the environment. And later I try to first print the whole env and then echo value of $HELLO.
Following snippet is from https://github.com/deepankarsharma/packer-plugin-lxdapi/blob/main/example/build.pkr.hcl#L32
environment = {
"HELLO": "WORLD"
inline = [
"env",
"echo $HELLO",
I can see that the HELLO variable does indeed show up in the env.
==> lxdapi.instance: stdout: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
==> lxdapi.instance: container=lxc
==> lxdapi.instance: HELLO=WORLD
==> lxdapi.instance: HOME=/root
==> lxdapi.instance: USER=root
==> lxdapi.instance: LANG=C.UTF-8
However I do not see any variable substitution taking place in the commands themselves as shown by the following output
==> lxdapi.instance: shell_exec: echo $HELLO
==> lxdapi.instance: rcode: 0
==> lxdapi.instance: stdout: $HELLO
==> lxdapi.instance: stderr:
Instead of the value of HELLO being substituted for $HELLO, I see an output of $HELLO in stdout.
Would appreciate any pointers on what I need to do to have variable substitution in commands passed in to the ExecInstance api.
