I am getting a seemingly erratic error when launching a container. Sometimes the launch works and most of the times it does not.
$ lxc launch ubuntu:18.04 --profile default --profile x11 mycontainer
Creating mycontainer
Starting mycontainer
Error: Error occurred when starting proxy device: Error: Failed to listen on /home/ubuntu/pulse-native: listen unix /home/ubuntu/pulse-native: bind: no such file or directory
Try `lxc info --show-log local:mycontainer` for more info
The LXC profile is:
environment.DISPLAY: :0
environment.PULSE_SERVER: unix:/home/ubuntu/pulse-native
nvidia.driver.capabilities: all
nvidia.runtime: "true"
user.user-data: |
#cloud-config
runcmd:
- 'sed -i "s/; enable-shm = yes/enable-shm = no/g" /etc/pulse/client.conf'
packages:
- x11-apps
- mesa-utils
- pulseaudio
write_files:
- owner: root:root
permissions: '0644'
append: true
content: |
PULSE_SERVER=unix:/home/ubuntu/pulse-native
path: /etc/environment
description: GUI LXD profile
PASocket1:
bind: container
connect: unix:/run/user/1000/pulse/native
listen: unix:/home/ubuntu/pulse-native
security.gid: "1000"
security.uid: "1000"
uid: "1000"
gid: "1000"
mode: "0777"
type: proxy
X0:
bind: container
connect: unix:@/tmp/.X11-unix/X1
listen: unix:@/tmp/.X11-unix/X0
type: proxy
mygpu:
type: gpu
used_by: []
The log output:
$ lxc info --show-log local:mycontainer
Remote: unix://
Created: 2020/04/19 05:07 UTC
Status: Running
Type: container
Profiles: default, x11
Pid: 25646
Ips:
eth0: inet 10.67.174.70 veth4755ada3
eth0: inet6 fd42:e196:7303:cb4f:216:3eff:fe6d:48b veth4755ada3
eth0: inet6 fe80::216:3eff:fe6d:48b veth4755ada3
lo: inet 127.0.0.1
lo: inet6 ::1
Resources:
Processes: 53
Disk usage:
root: 372.18MB
CPU usage:
CPU usage (in seconds): 138
Memory usage:
Memory (current): 421.92MB
Network usage:
Bytes received: 147.40MB
Bytes sent: 1.65MB
Packets received: 35745
Packets sent: 18693
lo:
Bytes received: 44.32kB
Bytes sent: 44.32kB
Packets received: 378
Packets sent: 378
Log:
lxc mycontainer 20200419050709.478 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.mycontainer"
lxc mycontainer 20200419050709.479 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.mycontainer"
lxc mycontainer 20200419050709.480 ERROR utils - utils.c:lxc_can_use_pidfd:1855 - Invalid argument - Kernel does not support waiting on processes through pidfds
lxc mycontainer 20200419050709.483 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1455 - No such file or directory - Failed to fchownat(17, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
By the way, I believe, this log does not show anything relevant for this problem. When I launch a container with the default profile, I get the same errors.
Could this be due to a problem on the host? How can I troubleshoot this?
