driver: lxc
driver_version: 2.1.0
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.4.0-141-generic
server: lxd
server_pid: 7000
server_version: “2.18”
storage: zfs
storage_version: 0.6.5.6-0ubuntu26
hi guys,
i have an issue here
suddenly one of my container can not running after restart …
when i start it give me an error
sudo lxc start netbeat
error: no such file or directory
Try lxc info --show-log netbeat for more info
the log give me information
"Failed to mount ZFS dataset “pool1/containers/netbeat” onto "/var/lib/lxd/storage-pools/pool1/containers/netbeat\
when i try to import it
sudo zpool import pool1
cannot import ‘pool1’: no such pool available
sudo zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
default 99.5G 31.0G 68.5G - 26% 31% 1.00x ONLINE -
pool-goodpeople 496G 195G 301G - 26% 39% 1.00x ONLINE -
pool-hutnet 298G 6.32G 292G - 0% 2% 1.00x ONLINE -
pool-newsnetmedia 199G 93.1G 106G - 46% 46% 1.00x ONLINE -
pool-wibnetmedia 39.8G 677M 39.1G - 3% 1% 1.00x ONLINE -
pool2 99.5G 22.8G 76.7G - 17% 22% 1.00x ONLINE -
sudo lxc storage list
| default | | zfs | default | 7 |
| pool-goodpeople | | zfs | pool-goodpeople | 2 |
| pool-hutnet | | zfs | pool-hutnet | 2 |
| pool-newsnetmedia | | zfs | pool-newsnetmedia | 1 |
| pool-wibnetmedia | | zfs | pool-wibnetmedia | 1 |
| pool1 | | zfs | pool1 | 1 |
| pool2 | | zfs | pool2 | 1 |
lxc storage show pool1
source: pool1
volatile.initial_source: /dev/loop1
zfs.pool_name: pool1
description: “”
driver: zfs
- /1.0/containers/netbeat
here is device list pool mapping
default /dev/sdb
pool-goodpeople /dev/sdh
pool-hutnet /dev/sdf
pool-newsnetmedia /dev/sde
pool-wibnetmedia /dev/sdg
pool2 /dev/sdd
sudo fdisk -l
Disk /dev/sdb: 100 GiB, 107374182400 bytes, 209715200 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 07ECDB3F-A5BF-A04E-93FE-655B1B1D6425
Device Start End Sectors Size Type
/dev/sdb1 2048 209696767 209694720 100G Solaris /usr & Apple ZFS
/dev/sdb9 209696768 209713151 16384 8M Solaris reserved 1
Disk /dev/sdc: 100 GiB, 107374182400 bytes, 209715200 sectors
Disklabel type: gpt
Disk identifier: FC9575B8-628B-9645-8D13-652F097C7D8D
/dev/sdc1 2048 209696767 209694720 100G Solaris /usr & Apple ZFS
/dev/sdc9 209696768 209713151 16384 8M Solaris reserved 1
Disk /dev/sdd: 100 GiB, 107374182400 bytes, 209715200 sectors
Disklabel type: gpt
Disk identifier: 3B02642A-105E-5143-80D7-346139CC0255
/dev/sdd1 2048 209696767 209694720 100G Solaris /usr & Apple ZFS
/dev/sdd9 209696768 209713151 16384 8M Solaris reserved 1
Disk /dev/sdf: 300 GiB, 322122547200 bytes, 629145600 sectors
Disklabel type: gpt
Disk identifier: CB099C00-CC73-164A-8DB8-52DFD1068008
/dev/sdf1 2048 629127167 629125120 300G Solaris /usr & Apple ZFS
/dev/sdf9 629127168 629143551 16384 8M Solaris reserved 1
Disk /dev/sde: 200 GiB, 214748364800 bytes, 419430400 sectors
Disklabel type: gpt
Disk identifier: 72492E8F-6322-F34B-8B3A-299435432C2B
/dev/sde1 2048 419411967 419409920 200G Solaris /usr & Apple ZFS
/dev/sde9 419411968 419428351 16384 8M Solaris reserved 1
Disk /dev/sdg: 40 GiB, 42949672960 bytes, 83886080 sectors
Disklabel type: gpt
Disk identifier: 6193DE6A-9003-E842-9F1B-FD77F5B79397
/dev/sdg1 2048 83867647 83865600 40G Solaris /usr & Apple ZFS
/dev/sdg9 83867648 83884031 16384 8M Solaris reserved 1
Disk /dev/sdh: 500 GiB, 536870912000 bytes, 1048576000 sectors
Disklabel type: gpt
Disk identifier: 464020E5-3E2E-1047-96A3-58AF8EE9F9D8
/dev/sdh1 2048 1048557567 1048555520 500G Solaris /usr & Apple ZFS
/dev/sdh9 1048557568 1048573951 16384 8M Solaris reserved 1
Disk /dev/sda: 24 GiB, 25769803776 bytes, 50331648 sectors
Disklabel type: dos
Disk identifier: 0x0846f7ac
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 999423 997376 487M 83 Linux
/dev/sda2 1001470 50329599 49328130 23.5G 5 Extended
/dev/sda5 1001472 50329599 49328128 23.5G 8e Linux LVM
Partition 2 does not start on physical sector boundary.
Disk /dev/mapper/vm–vg-root: 115.5 GiB, 124033957888 bytes, 242253824 sectors
Disk /dev/mapper/vm–vg-swap_1: 8 GiB, 8589934592 bytes, 16777216 sectors
any idea how to fix it ??
