From time to time, I’m unable to start new containers (tried with newly copied containers):
# lxc start work01-2021-10-06-06-33-04
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart work01-2021-10-06-06-33-04 /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/work01-2021-10-06-06-33-04/lxc.conf:
Try `lxc info --show-log work01-2021-10-06-06-33-04` for more info
When I inspect the log, it’s full of “No space left on device” when creating cgroups:
Status: STOPPED
Type: container
Created: 2021/10/06 06:34 UTC
Last Used: 2021/10/06 11:33 UTC
Log:
lxc work01-2021-10-06-06-33-04 20211006113300.976 ERROR cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:747 - No space left on device - Failed to create 13(lxc.monitor.work01-2021-10-06-06-33-04)
lxc work01-2021-10-06-06-33-04 20211006113300.976 ERROR cgfsng - cgroups/cgfsng.c:cgroup_tree_create:831 - No space left on device - Failed to create monitor cgroup 13(lxc.monitor.work01-2021-10-06-0
6-33-04)
lxc work01-2021-10-06-06-33-04 20211006113300.976 ERROR cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:747 - No space left on device - Failed to create 13(lxc.monitor.work01-2021-10-06-06-33-04-1)
6-33-04-1)
lxc work01-2021-10-06-06-33-04 20211006113300.976 ERROR cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:747 - No space left on device - Failed to create 13(lxc.monitor.work01-2021-10-06-06-33-04-2)
6-33-04-2)
(...repeated hundreds of times...)
lxc work01-2021-10-06-06-33-04 20211006113300.993 ERROR cgfsng - cgroups/cgfsng.c:__cgroup_tree_create:747 - No space left on device - Failed to create 13(lxc.monitor.work01-2021-10-06-06-33-04-999)
lxc work01-2021-10-06-06-33-04 20211006113300.993 ERROR cgfsng - cgroups/cgfsng.c:cgroup_tree_create:831 - No space left on device - Failed to create monitor cgroup 13(lxc.monitor.work01-2021-10-06-06-33-04-999)
lxc work01-2021-10-06-06-33-04 20211006113300.993 ERROR cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1067 - Numerical result out of range - Failed to create monitor cgroup
lxc work01-2021-10-06-06-33-04 20211006113300.993 ERROR start - start.c:__lxc_start:2002 - Failed to create monitor cgroup
lxc work01-2021-10-06-06-33-04 20211006113300.993 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:868 - Received container state "ABORTING" instead of "RUNNING"
lxc work01-2021-10-06-06-33-04 20211006113306.452 WARN cgfsng - cgroups/cgfsng.c:cgfsng_payload_destroy:538 - Uninitialized limit cgroup
lxc work01-2021-10-06-06-33-04 20211006113306.455 WARN cgfsng - cgroups/cgfsng.c:cgfsng_monitor_destroy:910 - Uninitialized monitor cgroup
lxc 20211006113306.459 ERROR af_unix - af_unix.c:lxc_abstract_unix_recv_fds_iov:220 - Connection reset by peer - Failed to receive response
lxc 20211006113306.461 ERROR commands - commands.c:lxc_cmd_rsp_recv_fds:129 - Failed to receive file descriptors
Running LXD 4.19 on Ubuntu 20.04, on AWS, with 5.11.0-1017-aws kernel.
Any idea how to fix it?
Note - it’s not a problem with i.e. rootfs out of space:
# df -h
udev 32G 0 32G 0% /dev
tmpfs 6.3G 1.1M 6.3G 1% /run
/dev/nvme0n1p1 39G 17G 22G 44% /
tmpfs 32G 0 32G 0% /dev/shm
tmpfs 32G 0 32G 0% /sys/fs/cgroup
/dev/loop0 34M 34M 0 100% /snap/amazon-ssm-agent/3552
/dev/loop1 25M 25M 0 100% /snap/amazon-ssm-agent/4046
/dev/loop3 100M 100M 0 100% /snap/core/11606
/dev/loop4 56M 56M 0 100% /snap/core18/2128
/dev/loop5 73M 73M 0 100% /snap/lxd/21497
/dev/loop6 56M 56M 0 100% /snap/core18/2074
/dev/loop7 62M 62M 0 100% /snap/core20/1026
/dev/loop8 62M 62M 0 100% /snap/core20/1081
tmpfs 1.0M 0 1.0M 0% /var/snap/lxd/common/ns
tmpfs 6.3G 0 6.3G 0% /run/user/0
/dev/loop10 100M 100M 0 100% /snap/core/11743
/dev/loop2 74M 74M 0 100% /snap/lxd/21624
