Hi fellow techies.
I recently try and set containers on Raspberry Pi 4 8GB version with 32bit installed OS on.
btw I use arch
Wanted to create small test server as a test digital battlefield to learn containers and server stuff without involvement of my main machine.
So I faced this problem below when tried set image of archlinux I was thinking was suitable for my 32bit Raspberry Arch version I have installed on the device.
$ sudo lxc launch images:archlinux/current/armhf ArchPSQL
Creating ArchPSQL
Error: Failed instance creation: Failed creating instance record: Failed initialising instance: Invalid devices: Failed detecting root disk device: No root device could be found
$ sudo lxc profile show default
config: {}
devices: {}
used_by: []
$ sudo lxc profile device add default root dist path=/ pool=default
Error: Device validation failed for "root": Failed loading device "root": Unsupported device type
So maybe any of you will notice something that I missed or did wrong so far.
To be noted that I don’t have too much experience with containers at all, I just barely started with LXD.
