Hi
I’m trying to do a lxc copy between two hosts. At the end of the copy (I see the 18G copied on the /containers/migration.996079115 folder on the target), I get the error message below. Initially thinking of a network issue, I’ve retried twice with the same effect.
Both hosts are using btrfs. Target disk is nearly empty. I’m not sure to understand why the message speaks about ./boot
What does that message mean? What can I do to fix it?
Thank you!
lxc copy tesct backupserver: --debug
Error: Failed instance creation:
- https://10.0.0.2:8443: Error transferring instance data: Unable to connect to: 10.0.0.2:8443
https://192.168.1.15:8443: Error transferring instance data: migration pre-dump failed
(00.029285) Warn (compel/arch/x86/src/lib/infect.c:281): Will restore 2789 with interrupted system call
(00.031322) Warn (compel/arch/x86/src/lib/infect.c:281): Will restore 2790 with interrupted system call
(00.149455) Warn (compel/arch/x86/src/lib/infect.c:281): Will restore 3230 with interrupted system call
(00.220372) Warn (compel/arch/x86/src/lib/infect.c:281): Will restore 3637 with interrupted system call
(00.408956) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./boot is inaccessible
(00.408958) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.408962) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./bin is inaccessible
(00.408964) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.408971) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./ is inaccessible
(00.408972) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.408984) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./boot is inaccessible
(00.408985) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.408988) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./bin is inaccessible
(00.408990) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.408997) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./ is inaccessible
(00.408999) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.409012) Error (criu/mount.c:1077): mnt: The file system 0x2d 0x2d (0x47) btrfs ./ is inaccessible
(00.409014) Error (criu/fsnotify.c:212): fsnotify: Can’t open mount for s_dev 2d, continue
(00.409015) Warn (criu/fsnotify.c:288): fsnotify: Handle 0x2d:0x7be0f cannot be opened
(00.418990) Error (criu/irmap.c:86): irmap: Can’t stat /var/lib/polkit-1/localauthority: No such file or directory
(00.419071) Error (criu/irmap.c:86): irmap: Can’t stat /no-such-path: No such file or directory
(00.419072) Error (criu/fsnotify.c:291): fsnotify: Can’t dump that handle
(00.419073) Error (criu/irmap.c:360): irmap: Failed to resolve 2d:7be0f
(00.419088) Error (criu/cr-dump.c:1567): Pre-dumping FAILED.
