Running:
lxd sql global "select * from storage_volumes_all WHERE name LIKE '%tracsvn-dev/snap%' ORDER BY name LIMIT 10"
seeing dupes:
| id | name | storage_pool_id | node_id | type | description | project_id | content_type | creation_date |
| 374 | tracsvn-dev/snap0 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 14396 | tracsvn-dev/snap0 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 382 | tracsvn-dev/snap1 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 14430 | tracsvn-dev/snap1 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 475 | tracsvn-dev/snap10 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 14923 | tracsvn-dev/snap10 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 484 | tracsvn-dev/snap11 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 14981 | tracsvn-dev/snap11 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 494 | tracsvn-dev/snap12 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15031 | tracsvn-dev/snap12 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
running:
lxd sql global "select * from storage_volumes_all WHERE name LIKE '%tracsvn-dev/snap1%' ORDER BY name"
I start seeing some with non-crazy creation dates
| 504 | tracsvn-dev/snap13 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15091 | tracsvn-dev/snap13 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 517 | tracsvn-dev/snap14 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15147 | tracsvn-dev/snap14 | 1 | 1 | 0 | | 1 | 0 | 2022-11-26T02:01:35.078400865Z |
| 526 | tracsvn-dev/snap15 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15204 | tracsvn-dev/snap15 | 1 | 1 | 0 | | 1 | 0 | 2022-11-30T02:01:07.282444301Z |
| 527 | tracsvn-dev/snap16 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15233 | tracsvn-dev/snap16 | 1 | 1 | 0 | | 1 | 0 | 2022-12-02T02:01:50.381070563Z |
| 536 | tracsvn-dev/snap17 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15295 | tracsvn-dev/snap17 | 1 | 1 | 0 | | 1 | 0 | 2022-12-06T02:01:13.195890766Z |
| 545 | tracsvn-dev/snap18 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15353 | tracsvn-dev/snap18 | 1 | 1 | 0 | | 1 | 0 | 2022-12-10T02:01:39.091491887Z |
| 554 | tracsvn-dev/snap19 | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 15413 | tracsvn-dev/snap19 | 1 | 1 | 0 | | 1 | 0 | 2022-12-14T02:01:41.055669054Z |
For the other server in question that has same issue, both of these were upgraded to Ubuntu 22 from 20 and are now running 5.10
lxc config show wordpress --expanded
environment.LANG: en_US.UTF-8
environment.LC_ALL: en_US.UTF-8
environment.LC_COLLATE: POSIX
limits.cpu: "4"
limits.cpu.allowance: 20%
limits.memory: 8GB
raw.lxc: lxc.mount.entry = none dev/shm tmpfs rw,nosuid,nodev,create=dir
snapshots.expiry: 30d
snapshots.schedule: 15 18 * * *
volatile.eth0.hwaddr: 00:16:3e:61:d7:92
volatile.idmap.base: "0"
volatile.uuid: 5a204571-166d-49dc-90d9-e2cb6e9c536b
nictype: bridged
parent: lxdbr0
pool: default
lxc storage show default | grep wordpress/
- /1.0/instances/wordpress/snapshots/after-2018-foss4g-moved
- /1.0/instances/wordpress/snapshots/after-change-to-dhcp
- /1.0/instances/wordpress/snapshots/after-imagemagick-bcmath-install
- /1.0/instances/wordpress/snapshots/after-moving-www-over
- /1.0/instances/wordpress/snapshots/bash
Note this one I have stopped a while ago, so all the snapshots that were set to expire have since disappeared.
lxc storage volume list default | grep wordpress/
| container (snapshot) | wordpress/after-2018-foss4g-moved | | filesystem | 1 |
| container (snapshot) | wordpress/after-2018-foss4g-moved | Auto repaired | filesystem | 1 |
| container (snapshot) | wordpress/after-change-to-dhcp | | filesystem | 1 |
| container (snapshot) | wordpress/after-change-to-dhcp | Auto repaired | filesystem | 1 |
| container (snapshot) | wordpress/after-imagemagick-bcmath-install | | filesystem | 1 |
| container (snapshot) | wordpress/after-imagemagick-bcmath-install | Auto repaired | filesystem | 1 |
| container (snapshot) | wordpress/after-moving-www-over | | filesystem | 1 |
| container (snapshot) | wordpress/after-moving-www-over | Auto repaired | filesystem | 1 |
| container (snapshot) | wordpress/bash | | filesystem | 1 |
lxd sql global "select * from storage_volumes WHERE name LIKE 'wordpress/%' ORDER BY name;"
| 1099 | wordpress/after-2018-foss4g-moved | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 1097 | wordpress/after-change-to-dhcp | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 1104 | wordpress/after-imagemagick-bcmath-install | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
| 1100 | wordpress/after-moving-www-over | 1 | 1 | 0 | | 1 | 0 | 0001-01-01T00:00:00Z |
lxd sql global "select * from storage_volumes_all WHERE name LIKE 'wordpress/%' ORDER BY name;"
| 21827 | wordpress/after-2018-foss4g-moved | 1 | 1 | 0 | Auto repaired | 1 | 0 | 0001-01-01T00:00:00Z |
| 21826 | wordpress/after-change-to-dhcp | 1 | 1 | 0 | Auto repaired | 1 | 0 | 0001-01-01T00:00:00Z |
| 21829 | wordpress/after-imagemagick-bcmath-install | 1 | 1 | 0 | Auto repaired | 1 | 0 | 0001-01-01T00:00:00Z |
| 21828 | wordpress/after-moving-www-over | 1 | 1 | 0 | Auto repaired | 1 | 0 | 0001-01-01T00:00:00Z |
| 26602 | wordpress/bash | 1 | 1 | 0 | | 1 | 0 | 2023-02-17T16:40:11.86741912Z |
