since a while my LXD service is not starting. I’m on debian 10 and LXD is installed with snap.
When I try to run it by hand, here is what I get :
sudo /usr/bin/snap run lxd.daemon
=> Preparing the system (21902)
==> Loading snap configuration
==> Setting up mntns symlink (mnt:[4026532582])
==> Setting up kmod wrapper
==> Preparing /boot
==> Preparing a clean copy of /run
==> Preparing /run/bin
==> Preparing a clean copy of /etc
==> Preparing a clean copy of /usr/share/misc
==> Setting up ceph configuration
==> Setting up LVM configuration
==> Setting up OVN configuration
==> Rotating logs
==> Setting up ZFS (0.7)
==> Escaping the systemd cgroups
====> Detected cgroup V1
==> Escaping the systemd process resource limits
==> Disabling shiftfs on this kernel (auto)
==> Detected kernel with partial AppArmor support
=> Re-using existing LXCFS
=> Starting LXD
WARN[12-13|14:05:02] - Couldn’t find the CGroup hugetlb controller, hugepage limits will be ignored
WARN[12-13|14:05:02] - Couldn’t find the CGroup memory swap accounting, swap limits will be ignored
WARN[12-13|14:05:02] Instance type not operational type=virtual-machine driver=qemu err=“vhost_vsock kernel module not loaded: Failed to run: modprobe -b vhost_vsock: modprobe: ERROR: could not insert ‘vhost_vsock’: Device or resource busy”
EROR[12-13|14:05:02] Failed to start the daemon err=“Failed initializing storage pool "lxd": Failed to run: zpool import lxd: cannot import ‘lxd’: no such pool available”
Error: Failed initializing storage pool “lxd”: Failed to run: zpool import lxd: cannot import ‘lxd’: no such pool available
This is the list of my zpools :
sudo zpool list -v
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
default 46,5G 9,15G 37,3G - 28% 19% 1.00x ONLINE -
/var/snap/lxd/common/lxd/disks/default.img 46,5G 9,15G 37,3G - 28% 19%
The default zpool is the correct one I guess, this is the list of zfs storages (I cropped the list):
zfs list -t all
default 9,15G 35,9G 24K none
default/containers 8,23G 35,9G 24K none
default/containers/bacula 3,00G 35,9G 3,13G /var/snap/lxd/common/lxd/storage-pools/default/containers/bacula
Has a migration failed or something similar?
Thank you for your help,
M.
