Hello.
I have a problem with the different machines when I try to start containers:
DBUG[12-17|01:05:31] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/9840d5ec-d18a-43a8-b9f1-d44cfebe356d etag=
DBUG[12-17|01:05:31] Got response struct from LXD
"id": "9840d5ec-d18a-43a8-b9f1-d44cfebe356d",
"class": "task",
"description": "Starting instance",
"created_at": "2021-12-17T01:05:31.449567441+03:00",
"updated_at": "2021-12-17T01:05:31.449567441+03:00",
"status": "Running",
"status_code": 103,
"resources": {
"instances": [
"/1.0/instances/gluster-0"
"metadata": null,
"may_cancel": false,
"err": "",
"location": "none"
Error: Failed to mount LVM logical volume: Failed to mount "/dev/default/containers_gluster--0" on "/var/snap/lxd/common/lxd/storage-pools/default/containers/gluster-0" using "ext4": input/output error
I can remove the default pool but I have to save my data from containers storage.
Logs:
[Fri Dec 17 01:34:42 2021] XFS (dm-16): Mounting V5 Filesystem
[Fri Dec 17 01:34:42 2021] XFS (dm-16): Ending clean mount
[Fri Dec 17 01:34:42 2021] xfs filesystem being mounted at /var/lib/docker/devicemapper/mnt/b2c40441045b7604b293f3d6bdd362186e4fa460a0c84e7e4393e5c50e33fd53-init supports timestamps until 2038 (0x7fffffff)
[Fri Dec 17 01:34:43 2021] XFS (dm-16): Unmounting Filesystem
[Fri Dec 17 01:34:43 2021] XFS (dm-16): Mounting V5 Filesystem
[Fri Dec 17 01:34:43 2021] XFS (dm-16): Ending clean mount
[Fri Dec 17 01:34:43 2021] xfs filesystem being mounted at /var/lib/docker/devicemapper/mnt/79f78fd0dceb3d39cafc4a7a0fec6241bc4d44479bbbb8035b9229464ea9ab3c supports timestamps until 2038 (0x7fffffff)
[Fri Dec 17 01:34:44 2021] XFS (dm-17): Mounting V5 Filesystem
[Fri Dec 17 01:34:44 2021] JBD2: Detected IO errors while flushing file data on dm-14-8
[Fri Dec 17 01:34:45 2021] EXT4-fs warning (device dm-4): ext4_end_bio:315: I/O error 3 writing to inode 137143 (offset 0 size 0 starting block 371200)
[Fri Dec 17 01:34:45 2021] XFS (dm-17): Ending clean mount
[Fri Dec 17 01:34:45 2021] containerd[205161]: segfault at 55f2f6938000 ip 000055f2f6938000 sp 00007ffdc5326bc8 error 14 in containerd[55f2f6b38000+d0a000]
[Fri Dec 17 01:34:45 2021] Code: Bad RIP value.
[Fri Dec 17 01:34:45 2021] xfs filesystem being mounted at /var/lib/docker/devicemapper/mnt/79f78fd0dceb3d39cafc4a7a0fec6241bc4d44479bbbb8035b9229464ea9ab3c-init supports timestamps until 2038 (0x7fffffff)
[Fri Dec 17 01:34:45 2021] EXT4-fs warning (device dm-4): ext4_end_bio:315: I/O error 3 writing to inode 131413 (offset 0 size 4096 starting block 622318)
[Fri Dec 17 01:34:45 2021] EXT4-fs warning (device dm-4): ext4_end_bio:315: I/O error 3 writing to inode 131357 (offset 0 size 4096 starting block 622319)
[Fri Dec 17 01:34:47 2021] XFS (dm-17): Unmounting Filesystem
[Fri Dec 17 01:34:47 2021] XFS (dm-16): Unmounting Filesystem
[Fri Dec 17 01:34:47 2021] EXT4-fs warning: 3 callbacks suppressed
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714084)
[Fri Dec 17 01:34:47 2021] buffer_io_error: 11 callbacks suppressed
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714084
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714085)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714085
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714086)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714086
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714087)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714087
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714088)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714088
[Fri Dec 17 01:34:47 2021] JBD2: Detected IO errors while flushing file data on dm-14-8
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714089)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714089
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714090)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714090
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714091)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714091
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714092)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714092
[Fri Dec 17 01:34:47 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714093)
[Fri Dec 17 01:34:47 2021] Buffer I/O error on device dm-14, logical block 714093
[Fri Dec 17 01:34:47 2021] XFS (dm-16): Mounting V5 Filesystem
[Fri Dec 17 01:34:48 2021] XFS (dm-16): Ending clean mount
[Fri Dec 17 01:34:48 2021] xfs filesystem being mounted at /var/lib/docker/devicemapper/mnt/79f78fd0dceb3d39cafc4a7a0fec6241bc4d44479bbbb8035b9229464ea9ab3c supports timestamps until 2038 (0x7fffffff)
[Fri Dec 17 01:34:48 2021] XFS (dm-16): Unmounting Filesystem
[Fri Dec 17 01:34:48 2021] XFS (dm-16): Mounting V5 Filesystem
[Fri Dec 17 01:34:49 2021] xfs filesystem being mounted at /var/lib/docker/devicemapper/mnt/f7a6583e808a6f56f15a0318d20f7d4759d13e135b82daadaa7a1cb0edc06bb2-init supports timestamps until 2038 (0x7fffffff)
[Fri Dec 17 01:34:50 2021] containerd[205282]: segfault at 55c8c5c7c000 ip 000055c8c5c7c000 sp 00007ffe3e3a3278 error 14 in containerd[55c8c5e7c000+d0a000]
[Fri Dec 17 01:34:50 2021] Code: Bad RIP value.
[Fri Dec 17 01:34:51 2021] XFS (dm-16): Unmounting Filesystem
[Fri Dec 17 01:34:52 2021] EXT4-fs warning: 17 callbacks suppressed
[Fri Dec 17 01:34:52 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 652042)
[Fri Dec 17 01:34:52 2021] buffer_io_error: 19 callbacks suppressed
[Fri Dec 17 01:34:52 2021] Buffer I/O error on device dm-14, logical block 652042
[Fri Dec 17 01:34:52 2021] Buffer I/O error on device dm-14, logical block 652043
[Fri Dec 17 01:34:52 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 652044)
[Fri Dec 17 01:34:52 2021] Buffer I/O error on device dm-14, logical block 652044
[Fri Dec 17 01:34:52 2021] Buffer I/O error on device dm-14, logical block 652045
[Fri Dec 17 01:34:54 2021] EXT4-fs warning (device dm-4): ext4_end_bio:315: I/O error 3 writing to inode 137143 (offset 0 size 0 starting block 371200)
[Fri Dec 17 01:34:54 2021] Buffer I/O error on device dm-4, logical block 371197
[Fri Dec 17 01:34:54 2021] Buffer I/O error on device dm-4, logical block 371198
[Fri Dec 17 01:34:54 2021] Buffer I/O error on device dm-4, logical block 371199
[Fri Dec 17 01:34:54 2021] Buffer I/O error on device dm-4, logical block 371200
[Fri Dec 17 01:34:54 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714105)
[Fri Dec 17 01:34:54 2021] Buffer I/O error on device dm-14, logical block 714105
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 714106)
[Fri Dec 17 01:34:55 2021] Buffer I/O error on device dm-14, logical block 714106
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 652046)
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 652048)
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 652049)
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 652050)
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 652051)
[Fri Dec 17 01:34:55 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 652052)
[Fri Dec 17 01:34:56 2021] containerd[205334]: segfault at 5628d898d000 ip 00005628d898d000 sp 00007ffd550a0308 error 14 in containerd[5628d8b8d000+d0a000]
[Fri Dec 17 01:34:56 2021] Code: Bad RIP value.
[Fri Dec 17 01:34:57 2021] JBD2: Detected IO errors while flushing file data on dm-14-8
[Fri Dec 17 01:34:57 2021] EXT4-fs warning: 6 callbacks suppressed
[Fri Dec 17 01:34:57 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 652057)
[Fri Dec 17 01:34:57 2021] buffer_io_error: 14 callbacks suppressed
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 652057
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 652058
[Fri Dec 17 01:34:57 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 271260 (offset 0 size 8192 starting block 714108)
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 714108
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 714109
[Fri Dec 17 01:34:57 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 131835 (offset 0 size 4096 starting block 714110)
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 714110
[Fri Dec 17 01:34:57 2021] EXT4-fs warning (device dm-14): ext4_end_bio:315: I/O error 3 writing to inode 132091 (offset 0 size 4096 starting block 714111)
[Fri Dec 17 01:34:57 2021] Buffer I/O error on device dm-14, logical block 714111
How to solve the problem?
