I have problem with the lxc when I want to launch a container. Here are the error logs. Could someone lead what could be the problem?
Thanks.
pine64@pine1:/var/lock$ lxc profile show default
config: {}
nictype: bridged
parent: br0
pool: default
- /1.0/containers/example1
pine64@pine1:/var/lock$ lxc launch images:ubuntu/xenial/arm64 example1
Creating example1
Starting example1
Error: Failed to run: /usr/lib/lxd/lxd forkstart example1 /var/lib/lxd/containers /var/log/lxd/example1/lxc.conf:
Try `lxc info --show-log local:example1` for more info
pine64@pine1:/var/lock$ lxc info --show-log local:example1
Remote: unix://
Architecture: aarch64
Created: 2018/05/27 06:51 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc 20180527065311.981 ERROR lxc_container - lxccontainer.c:wait_on_daemonized_start:815 - No such file or directory - Failed to receive the container state
lxc monitor log:
DBUG[05-27|09:51:45] handling ip=@ method=GET url=/1.0/events
DBUG[05-27|09:51:45] New event listener: b9bac84e-95ec-462d-b3c2-9bbb09b9cbff
DBUG[05-27|09:51:45] Responding to container create
DBUG[05-27|09:51:45] handling ip=@ method=POST url=/1.0/containers
DBUG[05-27|09:51:45] New task operation: 5e2bd105-b06c-496d-aa42-0e2be8b66090
DBUG[05-27|09:51:45] Started task operation: 5e2bd105-b06c-496d-aa42-0e2be8b66090
DBUG[05-27|09:51:45] Connecting to a remote simplestreams server
DBUG[05-27|09:51:45] handling ip=@ method=GET url=/1.0/operations/5e2bd105-b06c-496d-aa42-0e2be8b66090
DBUG[05-27|09:51:46] handling ip=@ method=GET url=/1.0
DBUG[05-27|09:51:46] handling ip=@ method=GET url=/1.0/containers
DBUG[05-27|09:51:48] Image already exists in the db image=e19a716f8b1cfaf156dbcbb5cf360d32ccfa146fe64a7b6e7ff298304b42874d
DBUG[05-27|09:51:48] Database error: &errors.errorString{s:"sql: no rows in result set"}
INFO[05-27|09:51:48] Creating container ephemeral=false name=example1
DBUG[05-27|09:51:48] Initializing a DIR driver.
INFO[05-27|09:51:49] Created container ephemeral=false name=example1
DBUG[05-27|09:51:49] Creating DIR storage volume for container "example1" on storage pool "default".
DBUG[05-27|09:52:06] handling ip=@ method=GET url=/1.0
DBUG[05-27|09:52:06] handling ip=@ method=GET url=/1.0/containers
DBUG[05-27|09:52:06] handling ip=@ method=GET url=/1.0/containers/example1
DBUG[05-27|09:52:48] Shifting root filesystem "/var/lib/lxd/containers/example1/rootfs" for "example1".
DBUG[05-27|09:53:10] Created DIR storage volume for container "example1" on storage pool "default".
DBUG[05-27|09:53:10] Success for task operation: 5e2bd105-b06c-496d-aa42-0e2be8b66090
DBUG[05-27|09:53:10] handling ip=@ method=GET url=/1.0/containers/example1
DBUG[05-27|09:53:10] handling ip=@ method=GET url=/1.0/events
DBUG[05-27|09:53:10] New event listener: 8baa3b1a-bb9d-41ec-ad44-4805361eb7fc
DBUG[05-27|09:53:10] Disconnected event listener: b9bac84e-95ec-462d-b3c2-9bbb09b9cbff
DBUG[05-27|09:53:10] handling ip=@ method=PUT url=/1.0/containers/example1/state
DBUG[05-27|09:53:11] Started task operation: fe4dd37a-8599-4c35-8be5-8b174c1eb3b4
DBUG[05-27|09:53:11] New task operation: fe4dd37a-8599-4c35-8be5-8b174c1eb3b4
DBUG[05-27|09:53:11] handling ip=@ method=GET url=/1.0/operations/fe4dd37a-8599-4c35-8be5-8b174c1eb3b4
DBUG[05-27|09:53:11] Initializing a DIR driver.
INFO[05-27|09:53:11] Starting container action=start created="2018-05-27 09:51:48 +0300 +03" ephemeral=false name=example1 stateful=false used="1970-01-01 02:00:00 +0200 EET"
DBUG[05-27|09:53:11] handling ip=@ method=GET url=/internal/containers/8/onstart
DBUG[05-27|09:53:11] Scheduler: container example1 started: re-balancing
DBUG[05-27|09:53:11] Failure for task operation: fe4dd37a-8599-4c35-8be5-8b174c1eb3b4: Failed to run: /usr/lib/lxd/lxd forkstart example1 /var/lib/lxd/containers /var/log/lxd/example1/lxc.conf:
EROR[05-27|09:53:11] Failed starting container action=start created="2018-05-27 09:51:48 +0300 +03" ephemeral=false name=example1 stateful=false used="1970-01-01 02:00:00 +0200 EET"
DBUG[05-27|09:53:12] handling ip=@ method=GET url=/1.0
DBUG[05-27|09:53:12] Disconnected event listener: 8baa3b1a-bb9d-41ec-ad44-4805361eb7fc
DBUG[05-27|09:53:12] handling ip=@ method=GET url=/1.0/containers
stgraber
(Stéphane Graber)
May 28, 2018, 2:03pm
2
What does lxc config show example1 --expanded show you?
Also the output of lxc info would be useful.
And does the br0 bridge exist on the system?
bruce78
(Bruce)
October 14, 2019, 5:47am
3
I have a similar error to the one above… the host and container are both on Debian 9 and LXD is version 3.18. I know this problem get’s fixed when I reboot the host but I’d like to avoid that if possible?
Here are the debugging commands I’ve run so far… please let me know if you’ve any thoughts…
lxc start mycontainer
Leads to
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart mycontainer /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/mycontainer/lxc.conf:
Try `lxc info --show-log mycontainer` for more info
And in turn lxc info --show-log mycontainer gives
Remote: unix://
Created: 2018/12/10 08:06 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc mycontainer 20191014052607.400 ERROR conf - conf.c:run_buffer:352 - Script exited with status 1
lxc mycontainer 20191014052607.400 ERROR start - start.c:lxc_init:887 - Failed to run lxc.hook.pre-start for container "mycontainer"
lxc mycontainer 20191014052607.400 ERROR start - start.c:__lxc_start:1991 - Failed to initialize container "mycontainer"
lxc mycontainer 20191014052607.509 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:864 - No such file or directory - Failed to receive the container state
Then I run
lxc info --show-log mycontainer --expanded
Which returns
image.architecture: amd64
image.description: Debian stretch amd64 (20181101_05:24)
image.os: Debian
image.release: stretch
image.serial: "20181101_05:24"
limits.cpu: "1"
limits.cpu.priority: "0"
limits.memory: 1536MB
volatile.base_image: 998fcf009fc5b08e467cbb0a8e93693f3a4d3b75ca15958df68fabdd560721a9
volatile.eth0.hwaddr: 00:16:3e:85:b1:b9
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
nictype: bridged
parent: lxdbr0
pool: "2"
I also ran lxc monitor when trying to start the container ad this seemed like the pertinent error message but there were a bunch more that came up?
metadata:
context: {}
level: warn
message: ZFS returned EBUSY while "/var/snap/lxd/common/lxd/storage-pools/2/containers/br-zulip"
is actually not a mountpoint
timestamp: "2019-10-14T07:37:56.838362693+02:00"
type: logging
stgraber
(Stéphane Graber)
October 14, 2019, 3:45pm
4
Looks like some issues with zfs mounts. You may want to do:
grep containers/br-zulip /proc/*/mountinfo
Then look at the pid in one of the results and do:
nsenter -t PID -m – umount
And repeat until the grep returns no match at which point LXD should be able to mount it again.
This particular issue I believe was resolved in upstream zfs a little while back, effectively allowing for the same dataset to be mounted in two different namespaces, but it could be that your version of zfs doesn’t have that fix, or that it’s a different variant of the same issue.
bruce78
(Bruce)
October 15, 2019, 6:57am
5
Thank you… that fixed it! I’m running zfs 0.6.5.9-5 on the host… Debian 9…
chepalitos
(chepalitos)
December 19, 2023, 6:24pm
6
Hi!
I am experiencing this issue when starting or launching a container:
lxc start arch-tst
Returns:
Error: Failed to run: /usr/bin/lxd forkstart arch-docker-tst /var/lib/lxd/containers /var/log/lxd/arch-docker-tst/lxc.conf: exit status 1
lxc config show arch-tst --expanded
Returns:
image.description: Archlinux current amd64 (20231219_04:18)
image.os: Archlinux
image.release: current
image.requirements.secureboot: "false"
image.serial: "20231219_04:18"
image.type: squashfs
image.variant: default
volatile.base_image: 735b2b20c4c084f12aafe7be579384fa06167add653ed8fc86c68454fa74c1d3
volatile.cloud-init.instance-id: 165837d6-61d9-428a-8a51-76ea6ac211a6
volatile.eth0.host_name: veth368b38b2
volatile.eth0.hwaddr: 00:16:3e:5d:0e:84
volatile.uuid: 72eabbb6-f806-41fa-8e0d-73e0e4103510
volatile.uuid.generation: 72eabbb6-f806-41fa-8e0d-73e0e4103510
network: lxdbr0
pool: default
lxc info --show-log arch-tst
Returns
Status: STOPPED
Type: container
Created: 2023/12/19 14:29 -03
Last Used: 2023/12/19 14:29 -03
Log:
lxc arch-tst 20231219172955.618 ERROR conf - ../src/lxc/conf.c:lxc_map_ids:3701 - newuidmap failed to write mapping "newuidmap: uid range [0-1000000000) -> [1000000-1001000000) not allowed": newuidmap 14438 0 1000000 1000000000
lxc arch-tst 20231219172955.618 ERROR start - ../src/lxc/start.c:lxc_spawn:1788 - Failed to set up id mapping.
lxc arch-tst 20231219172955.618 ERROR lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:878 - Received container state "ABORTING" instead of "RUNNING"
lxc arch-tst 20231219172955.620 ERROR start - ../src/lxc/start.c:__lxc_start:2107 - Failed to spawn container "arch-tst"
lxc arch-tst 20231219172955.620 WARN start - ../src/lxc/start.c:lxc_abort:1036 - No existe el proceso - Failed to send SIGKILL via pidfd 17 for process 14438
lxc 20231219172955.700 ERROR af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Conexión reinicializada por la máquina remota - Failed to receive response
lxc 20231219172955.700 ERROR commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
This is in a recently lxd installed on arch linux.
Thanks!
stgraber
(Stéphane Graber)
December 19, 2023, 6:39pm
7
Your /etc/subuid and /etc/subgid is misconfigured
