I suppose that I have recently changed one of my cluster node config like that, ```lxc config set core.metrics_address “<Wrong_IP_Adress>:3456”. Now I get the following error.
Oct 03 23:07:20 pinehost1 lxd.daemon[28620]: => Starting LXD
Oct 03 23:07:20 pinehost1 lxd.daemon[28620]: t=2021-10-03T23:07:20+0300 lvl=warn msg=" - Couldn't find the CGroup blkio.weight, disk priority will be ignored"
Oct 03 23:07:20 pinehost1 lxd.daemon[28620]: t=2021-10-03T23:07:20+0300 lvl=warn msg="Instance type not operational" driver=qemu err="KVM support is missing" type=virtual-machine
Oct 03 23:07:21 pinehost1 lxd.daemon[28620]: t=2021-10-03T23:07:21+0300 lvl=eror msg="Failed to start the daemon" err="Bind network address: listen tcp 192.168.1.5:3456: bind: cannot assign requested address"
Oct 03 23:07:22 pinehost1 lxd.daemon[28620]: Error: Bind network address: listen tcp 192.168.1.5:3456: bind: cannot assign requested address
Oct 03 23:07:22 pinehost1 lxd.daemon[28620]: => LXD failed to start
Oct 03 23:07:22 pinehost1 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Oct 03 23:07:22 pinehost1 systemd[1]: snap.lxd.daemon.service: Failed with result 'exit-code'.
Oct 03 23:07:23 pinehost1 systemd[1]: snap.lxd.daemon.service: Service RestartSec=100ms expired, scheduling restart.
Oct 03 23:07:23 pinehost1 systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 568.
Oct 03 23:07:23 pinehost1 systemd[1]: Stopped Service for snap application lxd.daemon.
Oct 03 23:07:23 pinehost1 systemd[1]: Started Service for snap application lxd.daemon.
Can someone enlighten me that where can I find that parameter in the sqlite database?
Thanks.
