Hi, I am having issues with the LXD daemon refusing to start.
lxc info shows the following
$ lxc info
Error: Get "http://unix.socket/1.0": dial unix /var/snap/lxd/common/lxd-user/unix.socket: connect: connection refused
When I try to restart the service and check journalctl -xe
, I get the following
Jan 09 14:56:05 gold systemd[1]: Started Service for snap application lxd.daemon.
░░ Subject: A start job for unit snap.lxd.daemon.service has finished successfully
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ A start job for unit snap.lxd.daemon.service has finished successfully.
░░ The job identifier is 6922.
Jan 09 14:56:05 gold lxd.daemon[1740567]: => Preparing the system (24175)
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Loading snap configuration
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up mntns symlink (mnt:[4026533551])
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up kmod wrapper
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Preparing /boot
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Preparing a clean copy of /run
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Preparing /run/bin
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Preparing a clean copy of /etc
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Preparing a clean copy of /usr/share/misc
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up ceph configuration
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up LVM configuration
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up OVN configuration
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Rotating logs
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Setting up ZFS (2.1)
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Escaping the systemd cgroups
Jan 09 14:56:05 gold lxd.daemon[1740567]: ====> Detected cgroup V2
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Escaping the systemd process resource limits
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Disabling shiftfs at user request
Jan 09 14:56:05 gold lxd.daemon[25308]: Closed liblxcfs.so
Jan 09 14:56:05 gold lxd.daemon[25308]: Running destructor lxcfs_exit
Jan 09 14:56:05 gold lxd.daemon[25308]: Running constructor lxcfs_init to reload liblxcfs
Jan 09 14:56:05 gold lxd.daemon[25308]: mount namespace: 6
Jan 09 14:56:05 gold lxd.daemon[25308]: hierarchies:
Jan 09 14:56:05 gold lxd.daemon[25308]: 0: fd: 8: cpuset,cpu,io,memory,hugetlb,pids,rdma,misc
Jan 09 14:56:05 gold lxd.daemon[25308]: Kernel supports pidfds
Jan 09 14:56:05 gold lxd.daemon[25308]: Kernel does not support swap accounting
Jan 09 14:56:05 gold lxd.daemon[25308]: api_extensions:
Jan 09 14:56:05 gold lxd.daemon[25308]: - cgroups
Jan 09 14:56:05 gold lxd.daemon[25308]: - sys_cpu_online
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_cpuinfo
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_diskstats
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_loadavg
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_meminfo
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_stat
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_swaps
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_uptime
Jan 09 14:56:05 gold lxd.daemon[25308]: - proc_slabinfo
Jan 09 14:56:05 gold lxd.daemon[25308]: - shared_pidns
Jan 09 14:56:05 gold lxd.daemon[25308]: - cpuview_daemon
Jan 09 14:56:05 gold lxd.daemon[25308]: - loadavg_daemon
Jan 09 14:56:05 gold lxd.daemon[25308]: - pidfds
Jan 09 14:56:05 gold lxd.daemon[25308]: Reloaded LXCFS
Jan 09 14:56:05 gold lxd.daemon[1740567]: => Re-using existing LXCFS
Jan 09 14:56:05 gold lxd.daemon[1740567]: ==> Reloading LXCFS
Jan 09 14:56:05 gold lxd.daemon[1740567]: => Starting LXD
Jan 09 14:56:06 gold lxd.daemon[1741161]: time="2023-01-09T14:56:06+08:00" level=warning msg=" - Couldn't find the CGroup network priority controller, network priority will be ignored"
Jan 09 14:56:06 gold lxd.daemon[1741161]: time="2023-01-09T14:56:06+08:00" level=warning msg="Instance type not operational" driver=qemu err="KVM support is missing (no /dev/kvm)" type=virtual-machine
Jan 09 14:56:06 gold lxd.daemon[1741161]: time="2023-01-09T14:56:06+08:00" level=error msg="Failed to start the daemon" err="Bind network address: listen tcp :8443: bind: address already in use"
Jan 09 14:56:06 gold lxd.daemon[1741161]: Error: Bind network address: listen tcp :8443: bind: address already in use
However, sudo netstat -plnta | grep 8443
gives nothing.
It might also be worth noting that I think these issues started after I tried installing juju and bootstrapping with localhost. However, I had issues with that, and ended up snap remove --purge juju
. This did not resolve the issue with lxd though, even after a system restart.
