Hi Guys,
In My environment:
$ cat /etc/redhat-release
CentOS Linux release 7.5.1804 (Core)
$ uname -a
Linux X.X.X 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14 21:49:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I followed Installation (Linux) and then tried to start it and got following error:
$ minikube start
Starting local Kubernetes v1.10.0 cluster...
Starting VM...
Downloading Minikube ISO
171.87 MB / 171.87 MB [============================================] 100.00% 0s
Getting VM IP address...
Moving files into cluster...
Setting up certs...
Connecting to cluster...
Setting up kubeconfig...
Starting cluster components...
E0928 17:48:15.499373 15471 start.go:297] Error starting cluster: kubeadm init error
sudo /usr/bin/kubeadm init --config /var/lib/kubeadm.yaml --ignore-preflight-errors=DirAvailable--etc-kubernetes-manifests --ignore-preflight-errors=DirAvailable--data-minikube --ignore-preflight-errors=Port-10250 --ignore-preflight-errors=FileAvailable--etc-kubernetes-manifests-kube-scheduler.yaml --ignore-preflight-errors=FileAvailable--etc-kubernetes-manifests-kube-apiserver.yaml --ignore-preflight-errors=FileAvailable--etc-kubernetes-manifests-kube-controller-manager.yaml --ignore-preflight-errors=FileAvailable--etc-kubernetes-manifests-etcd.yaml --ignore-preflight-errors=Swap --ignore-preflight-errors=CRI &&
sudo /usr/bin/kubeadm alpha phase addon kube-dns
running command: : running command:
.: Process exited with status 1
$ echo $?
1
I can’t figure out what I’m doing wrong…
Please advise.
Thanks & Regards
Camillelola
