When I configure the following parameters for the container:
lxc config set zhang security.nesting true
lxc config set zhang security.privileged true
Starting the container will fail with the following error message:
I enable these two parameters because I want to use shared folders and Docker in the container. BTW my container uses nvidia.runtime: “true”,
Ask for your help, thank you very much!
