Hi.
The following error occurred when adding the tpm device to the vm. What should I do?
Thank you
The path property doesn’t make sense for TPM devices attached to virtual machines.
So doing the same command but without the path=/dev/tpm0 should work juts fine.
On Instance configuration - LXD documentation it says its required, maybe there should be a note here?
not really, there is already noted there its only required / available for containers
Dunno how i missed that my b!
